Old 07-23-2012, 02:05 AM   #1
Ironbear65
My Ride: 2001 BMW 325i
FR-X Relay harness
I finally decided to work on my FR-X set up for my 01 325i. I'm a little confuse right now how to install my relay harness that came with it. Anyone got the 9006 relay harness from retrofit source inc?? This is a picture but only know to plug into the positive and ground cables. Anyone has instructions and just tell me off their head what cable goes where? I posted a pic.
Ironbear65 is offline   Reply With Quote
Old 07-23-2012, 02:39 AM   #2
paraklas
My Ride: ESS TS2 320ci
http://forum.e46fanatics.com/showthr...=quad+bi+xenon
The kit consists of:
Ground + Battery power
Switched 12v which can be taken from the +ve feed of one of the existing headlights
2x outputs that will go into ballasts
If you want to install like I did, you will need to extend the 2 outputs.
Also, what are you actually trying to achieve?
go from Halogen to Xenon?
from factory Xenon to FXR Xenon
Quad Xenon?
Old 07-23-2012, 07:50 AM   #3
Ironbear65
I'm trying achieve from halogen to Fr-x bi-xenons.
Old 07-23-2012, 08:01 AM   #4
rguti153
My Ride: 2004 zhp / 2000 323i
U mean fxr
rguti153 is online now   Reply With Quote
Old 07-23-2012, 08:23 AM   #5
Ironbear65
oops, yep. thats what i meant. I just hate the iphone auto correct thing.
Old 07-23-2012, 08:25 AM   #6
paraklas
Factory plug from halogen wiring --> Input of ballast
Factory plug from halogen high-beam --> theretrofitsource high-beam spliiter plugs --> bi-xenon projector Solenoid (2 red wires, polarity irrelevant) and to H7 factory bulb
You don't need their wiring. You WILL have a bulb-out warning, unless you code your car for Xenons or use (less desired) the capacitor mod
Old 07-23-2012, 08:40 AM   #7
Ironbear65
I got the slitter plugs,, and the can-bus harness that will delete the "light out" light from my car. I ended up getting the Morimoto 5Five package, the FX-R are the updated ones comepare to the you posted in the forum.
Old 07-24-2012, 01:30 AM   #8
Ironbear65
Lol......when i took apart my headlights...after 2 years i did not know i had Depo headlights that looks like OEM....theres no bmw logo anywhere. But that does not stop me from continuing my project
Old 07-24-2012, 02:25 AM   #9
Ironbear65
Is there a way to take this out?
