Sponsored by BAVSOUND
Old 06-23-2003, 09:47 PM   #1
330LICIOUS
My Ride: E46
Question how/where to splice into stock wiring, any pics available?
i'm trying to figure out where and how to find the speaker wire bundle from teh stock deck so i can splice that to my amp.
and do i have to take out the rear panel, if so, how? i can't seem to locate the screws/bolts/etc.
thanks!!
330LICIOUS is offline   Reply With Quote
Old 06-23-2003, 11:30 PM   #2
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
In the trunk on the Driver's side. There's a wiring bundle going into the stock amp. You can find everything there.
Wiring Diagram
Picture borrowed from here: http://bimmer.roadfly.org/bmw/forums...1433274&page=2
SrCsTc is offline   Reply With Quote
Old 06-24-2003, 02:32 AM   #3
XcvX
My Ride: 1999 328i
Send a message via AIM to XcvX
Originally posted by SrCsTc
[B]In the trunk on the Driver's side. There's a wiring bundle going into the stock amp. You can find everything there.
SrCsTc I am therefor assuming that the factory amp is that black box.
SWED
XcvX is offline   Reply With Quote
Old 06-24-2003, 02:34 AM   #4
starscream
Broke as hell
My Ride: '01 330xi
isnt' that the HK amp?
STARSCREAM
BEFORE ACCIDENT '01 330xi
AFTER ACCIDENT '07 Infiniti G35x
starscream is offline   Reply With Quote
Old 06-24-2003, 04:53 AM   #5
330LICIOUS
My Ride: E46
thanks for the pic and link SrCsTc...
i have th HK system, and i thought the amp is underneath the rear deck panel?? what is that, the cd changer?
Old 06-24-2003, 08:53 AM   #6
SrCsTc
Banned
My Ride: 00 323Ci
Yes it is, and the HK amp looks the same.
Old 06-24-2003, 08:53 AM   #7
SrCsTc
Banned
My Ride: 00 323Ci
I think that's the sub amp you're thinking of.
Old 06-24-2003, 11:19 PM   #8
330LICIOUS
My Ride: E46
oooh! ok thanks! i'm gonna try to figure out how to get into that left side trunk tomorrow.
Old 06-25-2003, 12:38 PM   #9
daz
My Ride: 2003 Bmw Coupe 330ci
Send a message via AIM to daz
Hello,
Can the OEM amp be used with a non OEM amp. i.e., use the OEm amp to drive a small sub. Buy a 4 channel at 75 x4 at 4ohms to drive the front and rear speakers. Or does the OEM amp become a paper wieght?
daz is offline   Reply With Quote
Old 06-25-2003, 01:03 PM   #10
SrCsTc
Banned
My Ride: 00 323Ci
Yes.
Old 06-26-2003, 11:55 PM   #11
rome5982
My Ride: 99 323i
Hello,
You can continue to use the stock amp and the new amp. However, the stock amp has limitations............all of it's speaker outputs are filtered at different frequencies. Also, the stock amp does not have enough power on the rear speaker outputs to adequately power an aftermarket sub. Remember that the rear deck speakers are 2 ohms each, so if you replace them with typical aftermarket woofers that are 4 ohms, you will need twice the amp's power on that channel to get the same volume.
I still use my stock amp, but only to power the stock 2.5" mid speakers in each of my doors for filler sound. Unless you can find better speakers with similar impedence values as the stock ones, the amp is a paper weight.
18"ASA AR1/H&R CupKit/ECIS CAI/Stromung Exhaust/Zimmerman Rotors/Aluminum Interior Trim & Face Gauges/G2 Calipers/Clear Corners/Autometer Gauges/Mtech Front Bumper/Chrome Grill/UUC Shift Knob/OEM Rear Spoiler/Painted Moldings/Silver Gauge Rings/JL Audio 12W3V2 & 6.5 Coax/BA 6.5 ProSeries/Kicker KX600.4
rome5982 is offline   Reply With Quote
Old 06-28-2003, 04:54 AM   #12
330LICIOUS
My Ride: E46
rome5982,
i like the looks of ur subwoofer placement, the way u have the center backrest cut open showing the JL 12". i don't have the ski pass opening on my seat. if i cut a whole on the backseat, does that mess up the stability/strength/etc. of the seat?
how did u do it?
Old 06-28-2003, 09:49 AM   #13
rome5982
My Ride: 99 323i
rome5982,
how did u do it?
No it does not mess with the structural integrity of the seat. I did not originally have the ski pass cut out, I did it myself. Here is a link about this for both sedans and coupes. http://forum.e46fanatics.com/showthr...threadid=33058
