'01 325xi front end vibration when accelerating and turning simultaneously - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-19-2011, 08:54 AM   #1
mcstevemc
My Ride: 2001 325xi
Hi all. This is my first forum post to E46fanatics, so please excuse me if the topic has been covered elsewhere.
My issue: Minor front end vibration when turning/accelerating simultaneously in '01 325xi. Only noticable when accelerating and turning from a total, or near-total stop (i.e. turning out of an intersection from a stop). When I first noticed the issue I thought it was someting rolling around the car, but it wasnt. It's coming from the front end. Noise/vibration happens when turning left or right - not worse in one direction or the other.
Car is my wife's daily driver. I asked her about it and she said it's been going on for "a while." Not much to go on there...but it does seem to not be getting any worse.
Thoughts?
mcstevemc is offline   Reply With Quote
Old 12-19-2011, 09:38 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
check axles and diff fluid level also your suspension play.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-19-2011, 04:31 PM   #3
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Check to see if the Axle Boots are Cracked (could well be at 10 years old), if they are cracked, a good chance that the CV Joints on the Axles are bad/no lube, and will need to be replaced. Also, check the fluid level in the front diff and the transfer case. Jack the car up and push and pull the top and bottom of tire and see if there is excessive movement, if there is, the Lower Control Arm Ball Outer Ball Joints are bad, also take a good look at the Inner Ball Joints and the Read Lower Control Arm Bushings. And finally, make sure you don't have a Brake Caliper hanging up and have that you have more than 2/32" of brake pad and not metal on metal (the sensor only hits one side) and make sure that the backing plates haven't been bent and rubbing.
tomoyer is offline   Reply With Quote
Old 08-02-2013, 07:48 PM   #4
4hoods
My Ride: 02' 325xit 5sp white
My front driveshaft has pay at rear u joint. I can Poke it with my finger and it makes noise. Metal to metal. I have vibration 2nd and 3rd. Have done control arms and bushings. New springs and strut inner ball joint axle. Haven't got into rear driveshaft. New tires. Rear shocks and mounts and springs.
4hoods is offline   Reply With Quote
Old 08-04-2013, 09:11 PM   #5
Rickna
My Ride: '01 330xi - '09 IS-F
Look at the FCABs.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 08-07-2013, 01:01 PM   #6
mcopenha
My Ride: '01 325xi, '73 2002
i experienced something similar and it turned out to be horribly degraded lower ball joints. The entire control arm was vibrating when turning.
mcopenha is offline   Reply With Quote
