Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 11-21-2012, 04:24 PM   #41
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
Okay would either one thro a check engine light ?
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 12-15-2012, 01:21 AM   #42
DrkSide_RbL
My Ride: 99' 328i Sport Sedan
Send a message via AIM to DrkSide_RbL
a bad throttle body will throw a check engine light and usually eml+traction control lights.
DrkSide_RbL is offline   Reply With Quote
Old 02-15-2013, 02:54 PM   #43
03E40sick
i am still having the same problem and i am getting so frustrated, i dont know what to do anymore
Old 02-17-2013, 02:15 PM   #44
Dippinwandy
My Ride: 325i
Thats how I feel bro. And theres at least 3 more members here that also feel like this...
Dippinwandy is offline   Reply With Quote
Old 02-18-2013, 01:13 PM   #45
03E40sick
one of the guys that works at bmw , told me that it could the DME module
Old 02-18-2013, 01:36 PM   #46
Dippinwandy
My Ride: 325i
Thats not good... I still think that one of the wires that goes to the icv might be dead.
Old 02-18-2013, 01:44 PM   #47
Bluzzer
My Ride: E46 328Ci
Had the same issue. I drive with cold air kit. I found out it was one of the hoses after the filter there have losen op so it took air in after the filter..
Put i back together and i have driven without EML since
Bluzzer is offline   Reply With Quote
Old 02-18-2013, 01:45 PM   #48
GolfingDuck
My Ride: 540 & 330Ci M Sport
Aren't different headers a known cause of an EML on some cars?
GolfingDuck is offline   Reply With Quote
Old 02-19-2013, 05:40 PM   #49
03E40sick
I didn't know that plus I have aftermarket headers ..
Old 06-18-2013, 04:11 PM   #50
03E40sick
any updates ???
Old 10-29-2013, 10:07 AM   #51
endat
My Ride: hjvbfvk
I am in the same boat as you guys.. EML has been happening periodically for months (only when I cruise).. I have rebuilt or replaced new everything that is associated with this problem (and then some). No result.
I stopped caring why it does this, and I am getting used to just driving in limp mode.. also looking into how to disable this EML stuff because in my case, the car runs perfectly well. I cut off the BMW's funding (after $hundreds in parts for nothing).
endat is offline   Reply With Quote
Old 11-11-2013, 02:15 PM   #52
DPREZ-E46
My Ride: E46
Post White Smoke
Hi All,
quick question, yesterday I was driving my bimmer E46 325Ci coupe, interstate 5 San Diego southbound and getting close to Encinitas the car started to throw bunch of white smoke from the back pipe, and I noticed that it happens only when I push the gas and the gauge is at 80 miles. Does anyone know what it may be? I'll appreciate the feed back...
DPREZ-E46 is offline   Reply With Quote
Old 11-26-2013, 11:12 PM   #53
anacondatcu
My Ride: 2000 328i
I was having a problem getting the DSC then EML light which would come on while trying to accelerate mostly on highway or when using cruise control and car would try to work harder to keep same speed up inclines. It would severly decrease power and if over 55mph would not accelerate at all until i took foot off the gas and let lights clear after a second or 2.
I had codes for Idle speed controller and thermostat and both replaced, thermostat because it actually was bad, but still got same codes and same problem with brand new parts.
Anyway went around to multiple dealers and shops not getting anywhere...kept getting told to replace both parts again. Found a shop that actually looked for something else after telling them both parts were new and they found that a connector pin inside the DME had been bent into another pin. bent pin was for ICV and the pin it was contacting was for thermostat.
My suggestion would be if you've already replaced ICV then to look for wiring issues. check the connectors that actually plug into the ICV for damaged, burnt or shorted pins or wires. At one point my headlights would repeatedly flash on and off while driving at night and this ended up being a burnt pin in the TAILLIGHT bulb housing connector so it seems that weird things can happen with our electronics.
link to my thread with image
http://www.e46fanatics.com/forum/sho...d.php?t=855987
anacondatcu is offline   Reply With Quote
Old 04-19-2015, 07:41 PM   #54
diezzler
My Ride: X3, R53
Keep in mind that BMW's have very particular indicator sequences. An EML with Traction control light on is usually related to the speed sensors, TPS (flat tire), or something related in that area. Don't assume an EML light pertains to anything more without actually scanning the car, especially if you have multiple lights on. OBD2 scanned codes in most cases still won't tell you the specific problem, and only gives you a generic code that may or may not guide you to the general area/problem - and in some cases, a complete miss on BMW's in comparison to a more complete scan. You need to scan the module specific codes with either INPA or a more expensive scanner (IE: Big computer scanner like a snapon, etc) that can scan the modules.
You also may have to align/calibrate certain things with a scanner, like when you change a throttle position sensor. You have to calibrate it, otherwise it'll act funny or throw codes.
diezzler is offline   Reply With Quote
Old 04-19-2015, 10:35 PM   #55
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
PA Soft 1.4 can scan most ECUs on an E46 and is like $25 on ebay. Get this tool in your kit ASAP.
///Mmmmmm...
Old 10-01-2015, 10:19 AM   #56
tslavant
My Ride: 2003 325I
My maf caused this
Originally Posted by alinfaraonu View Post
I hawe problem ENGINE, EML and DSC,hand brake on all yellow.U find the problem pls help me
I had the bad idle and going dead problem too. I replaced my MAF and now I have the same lights coming on just like yours. I saw below that to check everything is sealed up. So can a bad seal on the MAF cause these lights to come on? I also just got the p1500 code. Also I belueve all these issues here are MAF related. I have a 2003 325i as well. I have cleaned my ICV earlier befor replacing the ICV. Do MAF need to be Calibrated or reset?
tslavant is offline   Reply With Quote
Old 08-25-2016, 06:15 AM   #57
lofaszjoska90
My Ride: 525i
I have the same issue, P1500 error code, EML and Traction Control comes up but very rarely in my 525i, but also have terrible idle when the engine is cold. Anyone has find the solution?
Forgot to mention that already half of the engine was replaced.
lofaszjoska90 is offline   Reply With Quote
Old 08-25-2016, 02:19 PM   #58
tslavant
My Ride: 2003 325I
cold start
If you have 100k+ miles and not replaced the CCV you need to, Replace your CCV and clean or replace ICV. I have a E46 3 series yours is a 5 series so equipment could be different... Also make sure their are no air leaks, usually the line going from CCV to oil pan is deteriorated... Check you air flow boots, too... Also run seafoam thru ur gas tank.
Old 08-28-2016, 05:18 AM   #59
lofaszjoska90
My Ride: 525i
Everything what you've wrote has been replaced or checked. New CCV, After ICV cleaned new ICV, air leaks checked with smoke test, new boots etc...
Old 09-01-2016, 06:13 AM   #60
tslavant
My Ride: 2003 325I
In that case I would check your coils, assuming your spark plugs have been replaced recently, Take the cover off over the coils and while the car is running unhook the coils one at a time. As you disconnect one coil play very close attention to how the engine is running if the engine runs rougher when disconnected the coil is fine, if there is no change how the engine is running that coil is bad. If your coils are fine, I would look at the MAF that it may need cleaned or replaced... After that maybe o2 sensors. Did you replace the valve cover gaskets? it gets really brittle over time and leaks...
325i, emission, eml, error code
