Old 07-26-2012, 04:32 PM   #1
Teddy7
My Ride: slides
A/C problems? Look here first
Replace your A/C control module. You will see many people tell you to replace the FSR or water valve. Both of these are important, but the biggest neglected part when discussing A/C problems on this forum is the module. I replaced the valve, FSR, and it wasn't until I replaced the actual electronic component (the on that you physically push the buttons on) that I experienced a perfect working A/C system again. I had hot air coming out of the footwells, and dash vents, while the face (middle vents were blowing cool air). Just buy a used new version (the reconfigured button layout version) of the A/C module. I'm not saying this will fix your problem indefinitely since many of you may have slightly different symptoms, but honestly my bet will always be with module first from now on when trying to fix these e46 a/c problems. Many people replace the valve and FSR with no improvements. I started with the FSR, it fixed my intermittent blowing issues (which is exactly what it's for and it's symptoms when going bad). I then thought my warm air was being caused by my valve since I even had my water/heater valve fuse blown, bought a new valve, replaced fuse.... Nothing. I bought the new version of our a/c module for these cars and my a/c instantly stopped mixing the hot air and started blowing ice cold again. Granted, buy at your own discretion, but it worked for me. Freezing in my car now, and I've been doing nothing but dripping in sweat for the past 4 years in Florida with no A/C. Just my 2 cents and thought I should share with everybody how I came to resolve my A/C issues.
Headers, TMS sways, TMS solid subframe/diff bushings, HPF Subframe Plates, BBS RX224s, 25mm spacers, H&R rears, DNA fronts, coupe front lip, CAI, trunk lip, racing front seats. Flat black headlight internals, hood "v", and kidneys. Deleted SAP, muffler, and armrest. 5 speed swap soon.
Teddy7 is offline   Reply With Quote
Old 07-26-2012, 04:35 PM   #2
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Wrong. If you have A/C problems (what kind of, btw?) you must DIAGNOSE the problem first. And only after this you should start replacing anything.
Nervous is offline   Reply With Quote
Old 07-26-2012, 04:38 PM   #3
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Please listen to this guy!!!!!!
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-26-2012, 04:53 PM   #4
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Agreed, but thanks for letting everyone know about something else that might cause an a/c issue that can be used when diagnosing the problem.
Old 07-26-2012, 05:46 PM   #5
Teddy7
My Ride: slides
Sorry I went off the assumption that everybody here should know to do that first. My apologies. This is mainly directed to the people who have diagnosed a faulty water/heater valve as the problem, but replace it to find the same problem. I am simply telling everybody here that this module caused exactly the same symptoms as a faulty water/heater valve would and replacing the valve plus fuses had no effect on the mixture of hot/cold air. If you already replaced your valve and seem to be at a dead end. Then this is your next step most likely. My b Nervous
Old 07-26-2012, 10:28 PM   #6
Nervous
Name of the topic makes no sense. It should be '.... Look here when you are ready to give up' or something like that.
Old 07-27-2012, 02:11 AM   #7
MJLavelle
My Ride: 2001 BMW 330ci
So, what did you pay for the module, and where did you get it?
Old 07-27-2012, 08:02 AM   #8
Teddy7
My Ride: slides
Paid around 60 for it used off ebay. Just make sure you go through a reputable seller. Brand new they vary quite a bit in price range. Just make sure you get the one that has individual fan buttons on the right of the orange display and individual temp buttons on the left of the orange display.
Use this for reference, the old one is much bigger than the new one.
Old 07-27-2012, 08:13 AM   #9
Teddy7
My Ride: slides
I agree, but not completely. This part will make sure your entire a/c climate control system is functioning properly before you start replacing parts. If this module is malfunctioning. I don't care what you do to the water valve. Your a/c is still going to mix hot air with cold air. The title should probably be: "Can't stop hot air from blowing into cabin? Look here first"
Old 07-27-2012, 08:19 AM   #10
jbeurotech
Regional Sponsor
Why not test the system properly. The water vale is NORMALLY OPEN the IHKA powers it closed. so HMM if ytou have power to the water valve than the IHKA is probably fine.....
Or just randomly replace parts LOL
Seth Thorson
Old 07-27-2012, 08:47 AM   #11
Teddy7
My Ride: slides
Well guess what, my water valve definitely had power going to it prior to the module change. I'm trying to make people realize that the electronics seem to malfunction in the older modules and seem to not relay the correct responses to climate control settings. Thus, if everything is getting power and working properly like my system was prior to the module swap, you will still have no idea why you are having a/c climate control issues when everything that is supposed to be the culprit is fixed. My module let me use all the settings and had, it simply wasn't doing them properly (hence why I think bmw stopped making the much larger, older one). We all know how hard it is to get bmw to recall their products.
