Old 07-26-2012, 05:27 PM   #1
My Ride: Lexus
Safety-wire + loctite + drilled BW OPN
Fun job. Friend's car. Doing mine sometime soon...
Background: supercharged 330i w / lightweight flywheel (I know--BEGGING for the OPN to come off)
Needless to say the nut was on the last thread and the sprocket was disconnected from the shaft. Fun times. Wasn't there during the failure but red oil light came on while driving. Friend says he shut it off right away but I can't say for sure.
Moment of truth is when we start it Friday... didn't bother to pull any bearings.
Old 07-26-2012, 07:07 PM   #2
ImolaSix
My Ride: '02 330Ci M-sport
Does your friend track his car?
ImolaSix is offline   Reply With Quote
Old 07-26-2012, 07:24 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Should've just gotten the ZHP self-locking nut. Pretty much solves the problem.
Old 07-26-2012, 07:40 PM   #4
Grande D
My Ride: E36 M3
Yep the ZHP is special in this case
The shaft can fail on the 330s, more-so it seems than with the E36 M3s. I would have done at least the VAC shaft/sprocket kit, if not the vaio oil pump.
Nice job, lotta work, and I hope it doesn't fail on your friend.
It will change your life!
Old 07-26-2012, 07:46 PM   #5
REKLESS ROB
My Ride: 2004 325ci
That nut is swimming in red loctite. Nice!
REKLESS ROB is offline   Reply With Quote
Old 07-26-2012, 07:59 PM   #6
dknightd
My Ride: 2002 330 cic
I don't know what the heck an OPN is. But if a nut is properly installed, with proper thread lock, and safety wired, I don't see how it can possibly come loose. Was this a stock part your friend overwhelmed with power, or, could it have been an improperly installed part?
dknightd is offline   Reply With Quote
Old 07-26-2012, 08:06 PM   #7
Grande D
My Ride: E36 M3
It is not loctite-d or safety-wired from the factory. It is a fairly common issues on tracked 3L M54s (the oil pump nut falling off). The issue he may have created is an imbalance in the sprocket/shaft which can cause it to shear in even more rare instances.
Old 07-27-2012, 01:21 AM   #8
My Ride: Lexus
I'd still want to safety wire a ZHP nut. Not sure I'd trust the factory self-locker or (micro encapsulant) as they call it... though you don't really hear of ZHP nuts falling off do you?
Doing my car fairly soon. Keeping an open mind.
And no track time on the car that I know of
Old 07-27-2012, 08:07 AM   #9
Grande D
My Ride: E36 M3
I don't think the ZHP nut solves the problem if you track often. If you just drive hard on the street and stay on top of your damper you should be fine.
Just google search (on this site) ATI Super Damper, M54B30 Harmonic Issues/Problems, vaio oil pump, VAC oil pump kit.
Old 07-27-2012, 08:12 AM   #10
Guest021715
Account closed.
Is it worth doing this on a 325?
Old 07-27-2012, 08:29 AM   #11
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
I never understood the safety wire. Do you drill through the side of the nut?
Old 07-27-2012, 09:29 AM   #12
My Ride: Lexus
Oh I know more than enough about this... as of years ago. C'mon man. You know I read
You can either drill it... (need a stationary drill press and really sharp diamond tipped drill bit) or buy one for $10 from bimmerworld. The safety wire, in case you don't know, basically holds the nut in relation to the sprocket so that if it ever becomes vibrated, it has less of a tendency to turn (because it can't turn)
With the shorter stroke, I don't think the B25 engines have the tendency the B30s do to vibrate. So now, I think you 325 guys should be fine.
Old 07-27-2012, 09:35 AM   #13
Guest021715
Account closed.
Damn it feels good to be a gangsta..
Old 07-27-2012, 06:37 PM   #14
Grande D
My Ride: E36 M3
Indeed.
Well if you did search, my apologies for assuming you didn't, why did you use the safety wire? It seems to cause issues on the M54s. Why not weld, "just" red loctite, or buy the VAC kit?
I can understand why it's a no on the oil pump- too expensive and hard to obtain.
