Old 07-27-2012, 05:21 PM   #1
Dr Snow
My Ride: 328i
IDECK review for stock E46 tape deck
IDECK review for stock tape deck
I have researched all the options on this forum and others to determine what I was going to do about my stock tape deck with no AUX input in my 1999 328i manual trans. I really wanted a solution to not only play my favorite internet radio stations with my Iphone in the car but determine the best location to attach a mount so I can see the phone easily when driving. I was leaning toward replacing the stock tape deck unit with a CD unit and adding the AUX cable as others on this site have done. Then I was going to mount a holder/charger somewhere in the cup holder area. I really was having a dilemma trying to figure out where am I going to mount my phone in a location that does not take over the space of one of the cup holders or get in the way of shifting.
Then I came across the IDECK, saw only one mention of it on the forum but the member had not purchased it.
The GOOD :
The best thing about this crazy little unit for me is the phone holder location, for me it's perfect. So perfect that if I had a CD unit I would want the phone exactly where the IDECK holds it.
This thing does work, you need to tinker with it a bit to get it to seat all the way in the deck to make contact with the tape head. Once you get it correct you are good to go. The sound for me is perfectly acceptable, (definitely much better than one of those FM broadcast units).
It comes with a charging cable that connects to the side and plugs into the lighter right below it. The unit will work without this cord but your phone/ipod will not charge.
It also come with various IPod holders for the different models. One of them holds my Iphone (no case) very well, however as shown in the photo I use a thin case on my phone and do not use any of the mounts. I was going to modify one to work for my phone in the case but after driving around without any holder and the phone simply plugged into the Ideck base it seems to be fine.
There is also an AUX input on the base of the unit opposite from the charger port. This can come in handy for a non Iphone, although I have not used this feature yet.
The BAD:
The IDECK is made for the IPOD not the IPHONE. What this means is you may get a message on your phone that says that it is not compatible, but you close the message and it will work fine. That's not the bad part...if you do use a Iphone like I do you hear that speaker interference when the cell towers switch..you know that sound...it sucks. Of course if you put your phone in airplane mode this goes away but who wants to do that? I have not played around with ways to eliminate this problem I'm sure I will figure something out.
You will need to play with this to make it seat into tape head correctly. What I did was heat up the plastic band that goes from the tape to the base and bend it a bit. Then I was good to go, If you get one you will see what I am talking about, its really not a big deal.
It's a little wobbly, it needs some support on the backside of the phone mount to keep it secure. I made some small l brackets out of aluminum and DB taped them to the back, this worked great.
Bottom Line:
If you are looking for a very inexpensive option to connect your Iphone to your BMW stock Tape unit without spending Hundreds of dollars this is worth a try. Hell...just get it, for $40 (on amazon) you will be playing your favorite tunes in your car in minutes and have a great holder and location for your phone.
ID:	462392   Click image for larger version
ID:	462393   Click image for larger version
Dr Snow is offline   Reply With Quote
aux options, ideck, tape deck
