Old 07-27-2012, 08:55 PM   #1
E46330iguy
My Ride: Supercharged 330i
2000 328 will not crank
I searched but cant seem to find an answer, my friend has a 2000 328i and sometimes it wont turnover. The lights and everything come on but the car dosent turnover when you turn the key. The starter dosent Even click What do you think this could be? If you try again it usually fires up right away. I told her to unhook the battery for a while and see if it helps but thats all i could think of.
The car is automatic
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 07-27-2012, 08:58 PM   #2
Usmc1028
My Ride: 1999 BMW 328i
Make sure its in "P" if it auto.
Or try using a different key.
Usmc1028 is offline   Reply With Quote
Old 07-27-2012, 09:08 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Ignition switches are known to be weak spots in these cars. Could also be a starter on the way out?
Ignition switch is about $60 and not too hard to replace.
