Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 5.00 average. Display Modes
Old 08-19-2012, 08:48 PM   #41
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
Great thread. If I may ask, where did you get your cable interface from?
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 08-19-2012, 09:09 PM   #42
Wickedly
My Ride: 2016 BSM ///M2
I soldered the 7 and 8th pins together and still doesn't work. any help also my unit looks different and I bought it from
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
Wickedly is offline   Reply With Quote
Old 08-19-2012, 09:31 PM   #43
jfoj
My Ride: 330CiC, M5, X5, E93
Did you get the driver installed for the cable??
What OS are you running? 32 or 64 bit?
You also need to have the cable installed in the ODB port to get the drivers to load as the chipset in the interface cable is powered from the car, not the USB port on the computer.
If you have anything other than Win XP, you may need to manually install the drivers.
Old 08-20-2012, 01:53 PM   #44
boongsin12
My Ride: none
Originally Posted by Jperry666 View Post
When I set my alarm settings to acoustic I still don't get any beep from the car? All the light settings work just not the beep ??
Sent from my SCH-I500 using Bimmer App
Do you have alarm on your car?
2001 330Ci
boongsin12 is offline   Reply With Quote
Old 08-20-2012, 02:02 PM   #45
Jperry666
My Ride: 2002 325i 5spd
No I don't I added the beep alternative mod today though so now it beeps.
Jperry666 is offline   Reply With Quote
Old 08-20-2012, 04:00 PM   #46
dknightd
My Ride: 2002 330 cic
Originally Posted by dknightd View Post
I'm trying to figure out to have my seat and mirrors automatically move to saved positions when the car is unlocked using the key remote.
The owners manual says that the car can be programmed to do this.
I have searched through all the PA Soft menus. I do not see this option.
Anybody know where it is, and how this is done? Maybe it is just missing in my version
(it seems there are lots of different versions of what people can do using the same software . . .)
Nobody has enabled key remote seat/mirror memory?
dknightd is offline   Reply With Quote
Old 08-20-2012, 04:10 PM   #47
cvx5832
My Ride: 325Ci, 325Cic, C300
I'd say the option is most likely there. I think that most that have done it did so with tools before BMW Scanner 1.4.0 became widely available, so nobody has bothered to look anymore. When I did it with GT1/DIS it was under "Seat/Mirror Memory".
cvx5832 is offline   Reply With Quote
Old 08-20-2012, 04:36 PM   #48
dknightd
That is what I thought as well. When I went in to seat and mirror memory area, I clicked on coding, but the recoding option was grayed out. Maybe I need different software and cable to do this. In which case I'll probably pass since this is just a nice to have feature - all I really wanted was to be able to open and close my top with remote, and to be able read codes. This software seems to be able to do that.
Sure would be nice though . . .
If you happen to hook up your computer to your car again can you tell me if you see this option. And if so, where. I'll give it another try later this week. Wife comes home next week - she hasn't seen the car yet (except in phone pictures) it sure would be nice if the extra key I bought for her could magically make the seat go where she wants If not, I'll just tell her to use the buttons on the side of the seat.
Edit: thanks for the pdf
Old 08-20-2012, 04:38 PM   #49
Wickedly
I have windows xp
I got the driver installed from the cd as well the driver from the cable. when i plug it in the car, it says a driver has been found and it installs itself.
how do you get the cable installed in the ODB port?
Old 08-22-2012, 10:31 AM   #50
alpine003
My Ride: BMW
Just to verify, you do have multiple keys programmed for the car, right? How many active keys do you see on your screen? Mine wasn't grayed out IIRC the last time I was in there. I'll check again the next time I hook it up.
alpine003 is offline   Reply With Quote
Old 08-22-2012, 11:34 AM   #51
dknightd
I do have two keys programmed to unlock the car. But one of them is fairly new. I'll have to hook it up again and see how many keys it recognises (maybe I'll even risk deactivating ones no longer in use ... maybe). I have one key programmed for selective unlock, the other to unlock on one push, so the computer and software is apparently working for both. Thanks for your help - good suggestion.
Old 08-22-2012, 02:26 PM   #52
lilbimmer
My Ride: 01 330ci Step
Send a message via Yahoo to lilbimmer
Subscribed.
"sim simma, who gat di keys to mi bimma" - beenie man
lilbimmer is offline   Reply With Quote
Old 08-27-2012, 02:59 AM   #53
BM3R 330
My Ride: 2002 330i
Originally Posted by iceberq View Post
whoaaa sooo
If I use this, and uncheck the "HOT check" and "COLD check" for the front turn signals, does this mean I can install LED turn signal lights, not use resistors, and still not throw an error? That would be awesome. If somebody has done this, please let me know.
Yes, 100% verified it works on my end... front corner LEDS from Ebay. no flickering,weird patterns,fast or slow, etc. just right.
I have a small signature
BM3R 330 is offline   Reply With Quote
Old 08-27-2012, 10:25 AM   #54
JohnIBarr01
whoaaa sooo
Just so I am not confused, what exactly do the Hot / Cold Check functions do?
Old 08-27-2012, 10:16 PM   #55
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Cold checks is when you first turn the ignition to position 2 and IIRC Hot checks is when the cars running or when you use the lights.
Shannon.
shannon1 is offline   Reply With Quote
Old 08-28-2012, 12:27 AM   #56
BM3R 330
My Ride: 2002 330i
Oh yea, I forgot to ask, How do you get the doors to lock after 2 mins of being unlocked without opening...?
I have that box checked and updated it, but it doesnt lock. Any other special boxes that need to be checked?
I also cant get my high beams to flash with the alarm activation/deactivation. Only the warning lights. And both boxes are checked.
Old 08-28-2012, 06:08 AM   #57
dknightd
I have decided it is not possible with this combination of hardware and software.
Old 09-23-2012, 12:46 AM   #58
Patton323I
My Ride: R1100GS E46 E53
Is It possible to program a brand new unused "virgin" key with this software? I have a new key I bought for my 05 X5 3.0 a while back. I talked to some lock smiths who told me that the only people who could do that is the BMW dealer, and they most likely wouldn't do it. And to be clear, I am talking about the immobilizer function, not key less entry (locking and unlocking the car). A little DIY would be hugely appreciated!
Patton323I is offline   Reply With Quote
Old 09-23-2012, 08:13 AM   #59
carborn
My Ride: E46,E91
No, it's impossible. You should search for EWS key programmer for this.
carborn is offline   Reply With Quote
Old 09-23-2012, 09:55 AM   #60
Patton323I
Is there a EWS programmer that you would recommend?
