Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 5.00 average. Display Modes
Old 03-02-2014, 10:58 PM   #121
Bishopgoldy
My Ride: '05 M3 '92 325is
Originally Posted by mikeetastic View Post
anyone know how to bring this back? i enabled this feature weeks ago but this is not working anymore after i changed my driver door broken key hole.
i have both of them checked but still not working..
thanks.
Try Reprogramming your Key to the car locks. by replacing the for it probably reset the EWS key and it needs to retether.
Bishopgoldy is offline   Reply With Quote
Old 03-02-2014, 11:01 PM   #122
Bishopgoldy
Originally Posted by agd320i View Post
I have PA Soft and i have a Euro spec 320i. Using PA I cannot get any form of DRL to come on despite having checked the tickbox. anyone know why this is? I would also like to have the front indicators on as sidelights when the headlamps are on (like on US cars) but the only way i can do this so far is by pulling the plugs on my euro sidelights (in the main beam assembly) and then switching on the sidelights but they they then switch off when i turn the headlamps on.
Thanks for the help!
Not to insult your intelligence but have you checked the Fuses. and as the other lighting combinations I have been screwing with them to try and duplicate what you want but I can't
Old 03-02-2014, 11:08 PM   #123
Bishopgoldy
Originally Posted by Ricardo J View Post
Morning!
One more thing... I notice that my light coding has fewer options that the one I saw here in this topic:
Mine:
Are you in Demo, or factory Mode? in the Reprogramming option? it should be in Normal Mode. I haven't tried it but it seems like that would be the only thing that would limit your options. Also do Car Ident to ensure your car came with those features!
Good Luck
Old 03-03-2014, 09:26 AM   #124
KaktusJaque
My Ride: 2003 325xi
Ok I want to change my "Service Intervals" in IKE.
I beleive (if memory serves me correctly) the Inspection Interval is based on gas through the engine thus the Liters setting is for the Inspection interval.
and the Kilometers is for Oil service.
Is this correct?
So if I want to change my Oil to 8,000 miles, I can change the Kilometer setting to 12,875 Km (the Km conversion from 8,000 miles)
Secondly
Can someone explain, in Service intervals, what the Min time to reset and the Min liters to reset settings are
*KJ---Don't Believe Everything That You Think! *
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Clean Your Dirty Wheels
2003 Touring 325 XiT (KJ's Ride)
2004 Coupe 325 Ci (Mrs. KJ's Ride)
KaktusJaque is offline   Reply With Quote
Old 03-04-2014, 01:37 AM   #125
dakineE46
My Ride: '04 325I, '00 323I
KJ, Q1- I think you are correct. Q2- iirc, you would just select the min default of the choices given as you can't type in a number. Maybe I am not understanding question exactly.
dakineE46 is offline   Reply With Quote
Old 03-04-2014, 01:37 PM   #126
dakineE46
I installed used LCM and got rid of dot but after install, my rear taillights are super dim and high beams don't work with stalk but I can flash them. To fix, would I change PWM? Change algorithm (to what)? Hex editor?
Sincerely, in over my head haha.
Old 04-09-2014, 11:23 PM   #127
turbotalon1g
My Ride: '02 330i
Thanks to Kmoy for this thread, while it got derailed by morons it is still very helpful.
turbotalon1g is offline   Reply With Quote
Old 04-12-2014, 11:52 AM   #128
fsfikke
My Ride: '03 320Ci
I'm looking for a way to change the interval of the headlight washers. When I installed them a while back I set them to spray three times for 1 second using NCS. But it's annoying as hell now
Can the BMW Scanner do that? Or do I need to find my old laptop and install NCS again...
fsfikke is offline   Reply With Quote
Old 05-02-2014, 06:14 AM   #129
jzz30man
My Ride: 323Ci
I had the same LCM screen with the fewer options. This is because the LCM's software version is older and it has only those options. I replaced my '99 module to a 2004 one and now I can adjust hot checking for example.
jzz30man is offline   Reply With Quote
Old 05-13-2014, 11:10 AM   #130
2shaee
My Ride: E46 318i
Can anyone know how to confirm turn signals when locking and unlocking the car with PA SOFT? Where is the option?
2shaee is offline   Reply With Quote
Old 05-13-2014, 11:36 AM   #131
Strykr24
My Ride: 2000 328Ci
http://forum.e46fanatics.com/showthread.php?t=997258
Coding instructions are at the bottom of the first post. Really easy.
Strykr24 is offline   Reply With Quote
Old 05-13-2014, 11:40 AM   #132
2shaee
My Ride: E46 318i
Yes but i see no right option. I want blinkers to flash when lock and unlock the car? Which field do i have to mark?
Old 05-13-2014, 12:29 PM   #133
Strykr24
My Ride: 2000 328Ci
Just make sure the "optical" or "visual" options are checked. Then "audible" is to hear it through the siren.
Old 05-13-2014, 12:43 PM   #134
czarmar
My Ride: '99 323i
Just a quick check - Does a DME from a '99 323i support live data? Mine is greyed out in PA Soft, although I can get live data from EWS. Perhaps PA Soft does not support live data from DME for some (older, perhaps) cars.
'99 323i Sedan 293K miles (RIP)
2014 i3 BEV
czarmar is offline   Reply With Quote
Old 05-13-2014, 12:49 PM   #135
Strykr24
My Ride: 2000 328Ci
My '00 328Ci doesn't support it, which sucks because that's one reason I got the software.
Old 05-13-2014, 12:53 PM   #136
2shaee
My Ride: E46 318i
Yes but i think that my car doesn't have alarm
Old 05-13-2014, 12:57 PM   #137
Strykr24
My Ride: 2000 328Ci
That's fine, you can still activate the visual parts of it. The lights will flash when you lock and unlock your car, and the clown nose on the mirror will flash.
Google search "e46 alarm coding" and it'll pull a bunch of stuff up.
Old 05-13-2014, 01:01 PM   #138
2shaee
My Ride: E46 318i
Thank you mate will try asap ) Also can you "write odometer-correct mileage" on e46 with pa soft?
Old 05-13-2014, 01:04 PM   #139
Strykr24
My Ride: 2000 328Ci
Haven't tried doing that as mine is only off by a few kms.
Old 07-15-2014, 01:44 PM   #140
Competition05
My Ride: 2005 m3 ZCP
I have a ecu evolve tune for my bmw m3 2005 purchased it with aftermarket headers and exhaust and I was curious if this cancels or overrides the ecu tune what so ever, I know the evolve is mechanical and engine wise but thought I'd make sure before purchasing the scanner!
Competition05 is offline   Reply With Quote
