E46 Convertible
Old 07-28-2012, 02:36 PM   #1
bionicactionman
My Ride: 320d convertible
power steering
hi to all you verts a bit of info if you dont mind . under bonnet on my 320cd 2005 e46 vert i have a cap saying ATF fluid only i presume this is power steering yes? does any one know what spacific oil i have to top up with? as i have heard the wrong oil will degrade the power steering rubbers. have looked in manual but cant find any info. any help is much appreciated
bionicactionman is offline   Reply With Quote
Old 07-30-2012, 03:11 PM   #2
kib
My Ride: bmw 04 e46 330 vert
if you phone main dealer they will tell you.
kib is offline   Reply With Quote
Old 07-30-2012, 04:29 PM   #3
Jimjar
My Ride: 2006 325Ci
The power steering reservoir is a black canister in the front of the engine
see here: http://klinquist.smugmug.com/photos/...82_Js3AM-M.jpg
The fluid that should be used is ATF type "Dexron III". Since Dexron III is no longer very available most people substitute Dexron IV which is supposed to be backwards compatible, although you may get some different opinions.
As a new e46 owner I suggest you read this excellent post by E46mango:
http://forum.e46fanatics.com/showthread.php?t=923563
Jimjar is offline   Reply With Quote
