Old 07-28-2012, 03:17 PM   #1
JEuby
My Ride: 2007 328i
?? Tire pressure warning light?
I'm a New member. Just bought a 2007 428i a week ago. Noticed a warning that was circular with a jagged bottom edge with exclamation mark inside. I think it refers to tire pressure. If so, after pressures are corrected (front 32/back 35psi) (correct pressures?) how do I get the light to go off?
JEuby is offline   Reply With Quote
Old 07-28-2012, 03:34 PM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Cool
2007 428i....E46?
is this spam? If not that is your Transmission Lamp and not a Tire Warning Lamp.
You NEED a new transmission...I hope you kept your reciept.
delmarco is offline   Reply With Quote
Old 07-28-2012, 03:45 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Tell us how you got an F32 already and WE WILL SPARE YOU
Old 07-28-2012, 04:11 PM   #4
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by delmarco View Post
2007 428i....E46?
Damn do BMW now use plastic transmissions?
Sent from my HTC Sensation 4G using Bimmer App
Old 07-28-2012, 09:07 PM   #5
JEuby
My Ride: 2007 328i
That's not the symbol I see. It looks like a horse shoe with jagged edges only on the bottom. Exclamation in the middle.
Thanks, tho
Old 07-29-2012, 04:01 AM   #6
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
There is a button near the shifter - you press it or press and hold it iirc
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 07-29-2012, 07:56 AM   #7
JEuby
My Ride: 2007 328i
Thanks!
Old 07-29-2012, 09:43 AM   #8
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
If you car has run-flat tires it has tire monitor system, believe it was also an option for cars that didn't have the run-flat tires. The yellow warning looks like a flat tire with "!" in the center. THis indicates that one or more of the tires doesn't have the correct air pressure in them. If the car has the tire air pressure monitor system, there should be a button just under the little compartment in front of the shifter that will/should re-set the warning light (provided that one or more of the wheel sensors isn't bad). The sensors in the wheels do go bad, so if air pressure in all 4 tires is correct and the light can not be re-set, have the codes read, the codes will tell you which wheel sensor(s) are bad.
tomoyer is offline   Reply With Quote
Old 07-29-2012, 11:15 AM   #9
delmarco
Thanks, tho
This horseshoe symbol? If so then it looks like you need a brand new transmission AND a new engine!
Did you keep the receipt?
Old 07-29-2012, 11:43 AM   #10
JEuby
My Ride: 2007 328i
Thanks to 'Tomoyer' for that explanation. I'll check the tire pressure & see if I can reset it.
Old 07-29-2012, 11:58 AM   #11
delmarco
Hey what about me?
Old 07-30-2012, 10:36 AM   #12
WALDE_BORA
My Ride: 99' 323i, 99' JETTA
Hey what about me?
have you checked the air pressure on your spate tire? It might have a sensor as well
WALDE_BORA is offline   Reply With Quote
Old 07-30-2012, 10:54 AM   #13
dpower2012
My Ride: 05 BMW 325CiC
Not sure if troll or just stupid.
dpower2012 is offline   Reply With Quote
Old 07-30-2012, 01:23 PM   #14
djnekkon
My Ride: MB3ci & z33 HR
You prob have a bad sensor. Why asking @e46 tho?
Old 07-30-2012, 02:00 PM   #15
JEuby
My Ride: 2007 328i
Thanks, sorry, didn't know I was at E46. Googled the question and followed the link. (Thanks; I'm outta here.)
pressure sensor, tire
