DSC error - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-29-2012, 10:26 AM   #1
captdchu
My Ride: z4
DSC error
hello all,
just got the handy dandy bavarian technic cable to try and resolve my DSC issue
my abs/brake/dsc lights all yellow
code reads...
5DF0:
DSC-ECU: ECU-internal: RAM adressing test- error
tried to clear it but it keeps coming back
does this mean my DSC ECU is shot? anyone with any experience?
thanks all
captdchu is offline   Reply With Quote
Old 07-29-2012, 12:12 PM   #2
fth001
My Ride: 325i, e36m3, s13
Your DSC hydraulic pump is dead, may it rest it peace. Thats a $1000 dollar repair bill. I think there's a DIY someplace, pretty easy one if you can do brakes.
fth001 is offline   Reply With Quote
Old 07-29-2012, 06:16 PM   #3
captdchu
My Ride: z4
ouch! $1000
is the dsc same as the abs?
thanks
Old 07-30-2012, 12:50 AM   #4
fth001
The dsc pump is actually a part of the abs. Here is a link for an E90 but its pretty much the same. http://www.e90post.com/forums/showthread.php?t=600491
Old 08-01-2012, 08:52 AM   #5
captdchu
My Ride: z4
Thank you for the response and link... Does not look too difficult... I'm trying to figure out if it's for sure the pump and not the module... Since the code is a ram memory error, any ideas?
Old 08-02-2012, 01:30 AM   #6
fth001
Hmmm.... good question, not sure I can help you there. I've done this repair only a few times and I've always replaced the entire unit.
Old 08-03-2012, 02:59 PM   #7
captdchu
My Ride: z4
was thinking just to replace the whole unit as well
did you have to have the module programmed? where did you get the parts from?
thanks
Old 08-04-2012, 02:09 AM   #8
fth001
Ebay, and yeah you have to get it coded after. Just found a list of error codes and it looks like it would be the pump itself. There are other codes for the control unit so you should be able to just switch the pump and skip the coding part. GL
5DF0
Pump unit
5DF2
Valve / ECU hardware failure
5DF4
Wiring supply voltage < 9 Volt
5DF5
Control unit internal failure
5DF7
Wiring supply voltage > 18 Volt
Old 08-05-2012, 01:08 PM   #9
captdchu
My Ride: z4
cool... thanks for all your help
