Old 07-29-2012, 12:33 PM   #1
Hbenmeir
My Ride: 01 330ci
Service engine light
My service engine light comes on and goes off on it on accord. It will be off for like 1000miles then come on for a few hundred on and off for a while now . I had it looked at lean bank 1 2 and a misfire anyone have any ideas
Hbenmeir is offline   Reply With Quote
Old 07-29-2012, 01:38 PM   #2
kondzik
My Ride: 330i
leak on the intake or cvv
kondzik is offline   Reply With Quote
Old 07-29-2012, 02:26 PM   #3
zhenkaaaM3
My Ride: Fst'r then your e46
MAF. But look for slits and cracks on intake
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 07-29-2012, 02:42 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first 2 links below in my signature.
Old 07-29-2012, 03:57 PM   #5
Hbenmeir
My Ride: 01 330ci
I do live at 6500ft and top grade fuel here is 91 maybe 92 could that have anything to do with it
Old 07-29-2012, 06:22 PM   #6
Hbenmeir
My Ride: 01 330ci
I did just discover quite a few cracks in the tube from the throttle bodie to the mad.anyone have an extra
Old 07-29-2012, 09:46 PM   #7
zhenkaaaM3
I dont think cracks would do it. If the cracks are letting air out, then yes. It can cause a slight misfire. I had this.. this led to 6 misfires.
Old 07-29-2012, 10:59 PM   #8
Hbenmeir
My Ride: 01 330ci
That's actually we're it's cracked I'm taking it in to get the front end looked at tomorrow and I'll gave them order a new hose
Old 07-29-2012, 11:26 PM   #9
MJLavelle
My Ride: 2001 BMW 330ci
Order it online, and save a ton of money. The dealer charges too much.
Old 07-29-2012, 11:37 PM   #10
zhenkaaaM3
its a cheap part. I didnt even feel misfires. It was so minimal.
Eugene
Old 07-30-2012, 09:21 AM   #11
Hbenmeir
My Ride: 01 330ci
Should I replace both the cracked one is $31at auto parts warehouse and the other is $16 same place
Old 07-30-2012, 09:23 AM   #12
jasonbimmer
My Ride: 2001 BMW 330xi
I would do both while in there.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 07-30-2012, 09:25 AM   #13
Hbenmeir
My Ride: 01 330ci
Or is the one off the throttle bodie a bitch to change cause It looks like it
Old 07-30-2012, 09:25 AM   #14
ChrisRedmon
My Ride: 2002 PY ///M3
You cant drive around thousands of miles with the HELP ME light on dude! Come on!
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 07-30-2012, 09:38 AM   #15
Hbenmeir
My Ride: 01 330ci
If it doesn't stay on constant I don't worry considering all the things that could cause the light to come on that are simple like not running 93+ octane or the gas cap not being tight or simple things it's getting fixed today anyways
Old 07-30-2012, 10:15 AM   #16
0mega9
My Ride: 330Xi
There are a dozen or so reasons why the service light would come on; for me, it has been a lose gas cap after refilling. I actually had to buy a new gas cap to replace the one the one I had. Since then, 3 months already, I haven't seen that light again...
0mega9 is offline   Reply With Quote
Old 07-30-2012, 10:35 AM   #17
jfoj
Should be about $15-20 per elbow from www.bmwmeredesparts.com and they probably offer free shipping as well.
Old 08-04-2012, 12:06 PM   #18
Hbenmeir
My Ride: 01 330ci
Lean in bank 1 and 2 a misfire detected and low fuel. Already replaced the first boot from the maf to the throttle bodie what's next fuel filter or pump
Old 08-04-2012, 12:18 PM   #19
kondzik
My Ride: 330i
Perform a smoke test and see whats else is leaking
Old 08-04-2012, 11:03 PM   #20
Hbenmeir
My Ride: 01 330ci
Never heard of that could you tell me how
