Old 08-05-2012, 12:06 AM   #21
jfoj
My Ride: 330CiC, M5, X5
Visual inspection will find most of what a smoke test can indicate assuming you know what to look for.
Again, suggest anyone with lean codes and misfires to read the first link below in my signature.
Old 08-06-2012, 10:12 AM   #22
Hbenmeir
My Ride: 01 330ci
On bimmers lean with low fuel can that cause a misfire. Do I have to worry about this being ignition related or just vacuum and fuel system
Hbenmeir is offline   Reply With Quote
Old 08-06-2012, 10:51 AM   #23
jfoj
The low fuel is usually detected by the O2 sensors. So a lean mixture does not have enough fuel, therefore on the extreme end of lean you will also see misfire with low fuel based upon what the O2 sensor is reading.
Lean conditions cause misfires, sometimes not even really detectable when driving the car.
Ignition can contribute, however, most ignition related problem are far more obvious and usually happen under load, more likely at lower RPM in 3rd-6th year or with the torque converter clutch locked up.
You need to see if your car is also triggering P0171 & P0174 along with the misfire codes and check everything outlined in the first link in my signature.
Old 08-06-2012, 10:55 AM   #24
Hbenmeir
My Ride: 01 330ci
Ok well I found my problem cause if my car has a miss I'll kiss your ass so o2 sensor thank you
Old 08-07-2012, 10:00 AM   #25
Hbenmeir
My Ride: 01 330ci
How many o2 sensors are on these cars? Are they only in the exhaust
Old 08-07-2012, 10:35 AM   #26
jfoj
4 total, 2 pre Cat & 2 post Cat, but not sure why you are interested in changing the O2 sensors as they are not likely your problem.
Old 08-25-2012, 08:28 PM   #27
0mega9
My Ride: 330Xi
While an O2 sensor may be the cause, so could a number of possible gas/air leaks throughout system b4 it gets to engine...
For me it was the gas-cap...
The seal inside it was too old...
Once I replaced the cap..., no more light....
0mega9 is offline   Reply With Quote
