Old 07-29-2012, 11:37 PM   #1
talol85
My Ride: e60 m5 - e46 m3 vf 2
e46 m3 vf stage 2 intake manifold water level and air bleed
hi to all
i have a e46 m3 with vf stage 2 2003
i want to know what is the intake manifold water level and how bleed air from the sc cooler ?
i live in kuwait and it is here very hot it goes over 122f
talol85 is offline   Reply With Quote
Old 07-30-2012, 11:32 PM   #2
Forcefed M3
My Ride: HPF Stage 2.75
You want it full to the top so that you plug pushes a little water out, your pump should be running 100% of the time when the cars running. Keep the car running while you have the plug out, keep pouring water in until it starts to come out. Put the plug in and your good to go!
Forcefed M3 is offline   Reply With Quote
Old 07-31-2012, 12:30 AM   #3
talol85
thanks for u help
these days the weather is very hot it is going to 122f
i noticed that the car gets hoter when i fill it to the top i noticed that in traffic or when the car stops
i don't know why any help do i need to add water wetter or bmw blue water in my sc cooling system ?
Old 07-31-2012, 02:32 AM   #4
Forcefed M3
Wetter water will help. Remember your engine temp is seperate from your VF set up. Check your fan clutch to make sure it's working right! Good luck!
Old 08-09-2012, 02:38 AM   #5
C3855
My Ride: E46m3
So did bleeding the air out of the system solve the problem? I have a stage ii vf and the same symptoms, (car temp gauge starts creeping up to red with the ac on ...)
C3855 is offline   Reply With Quote
Old 08-09-2012, 06:58 PM   #6
Forcefed M3
Check your fan clutch.
Old 08-12-2012, 03:13 PM   #7
sonnydm3
My Ride: 2004 m3
hi,i have vf stage 2 and i find small funnel while pump is working fill it and how much system need it,ll take it as need itand turn ign off c it may take it more,also used water wetter addive its keeps it coler
sonnydm3 is offline   Reply With Quote
Old 08-17-2012, 06:24 PM   #8
talol85
well it is the same
maby i will need a after market radiator
Old 03-06-2013, 07:09 PM   #9
C3855
My Ride: E46m3
Update
Originally Posted by talol85 View Post
well it is the same
Well just giving an update for any Vf guys having these technical difficulites. My car was running warm because the engine mounts were bad causing the engine to sit further back in the engine bay causing the radiator fan to scrape against the plastic housing on the radiator causing the fan to spin slower and less freely. So I had the engine mounts and fan replaced, upgraded to hpf fan clutch and problem solved.
