Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 3.91 average. Display Modes
Old 08-24-2012, 11:57 AM   #101
lsteg
My Ride: 2001 330ci
This is one of my favorite threads. Just waiting till some of these bugs are worked out to purchase.
Tip of the hat to nmcclana.
lsteg is offline   Reply With Quote
Old 08-24-2012, 12:30 PM   #102
kmartgt
My Ride: 2002 M3 Convertible
I apologize if I have just over looked it, but are there explicit instructions right now to setup bluetooth music streaming?
///MARTINY
kmartgt is offline   Reply With Quote
Old 08-24-2012, 01:16 PM   #103
JasonSmithed
My Ride: 00 323i
No I couldn't find how to display texts tweets and emails either
JasonSmithed is offline   Reply With Quote
Old 08-24-2012, 06:48 PM   #104
JasonSmithed
My Ride: 00 323i
I still can't find the port for the disc changer. Any help?
Old 08-25-2012, 04:43 AM   #105
nmcclana
My Ride: 2000 323i
@lsteg -thanks! It's almost there,probably one more week to clean things up
@kmartgt - not yet, but it's coming up. It's straightforward.
nmcclana is offline   Reply With Quote
Old 08-25-2012, 05:38 AM   #106
CSL323
My Ride: 330Ci
You'll see like, a rubber/foamy thing it's hard to describe but it's rolled up. Inside are cloths wrapped around wires. They are your cd changer wires
CSL323 is offline   Reply With Quote
Old 08-26-2012, 02:04 PM   #107
JasonSmithed
My Ride: 00 323i
Got it. Clever.
Old 08-26-2012, 02:39 PM   #108
JasonSmithed
My Ride: 00 323i
Thanks I found it zip tied behind the other wiring harness hidden
Old 08-26-2012, 09:58 PM   #109
JasonSmithed
My Ride: 00 323i
I would buy this just to reprogram but I'm not good at source and there isn't a tutorial on anything other than what's on the install instructions
Old 08-27-2012, 09:30 AM   #110
CSL323
My Ride: 330Ci
Need a release ASAP!! Long drive coming up and fast
Old 08-27-2012, 12:42 PM   #111
nmcclana
My Ride: 2000 323i
@CSL - coming up! First bug is fixed, just finishing the second bug. I've added a ton of features, too.
Old 08-27-2012, 12:47 PM   #112
wsmeyer
My Ride: 330CiC
How about making it so the live bus data also shows commands coming from the Kracker? That would make troubleshooting a debugging our own routines a bit easier.
wsmeyer is offline   Reply With Quote
Old 08-27-2012, 05:37 PM   #113
CSL323
My Ride: 330Ci
Hooray push it out ASAP! Think you've got the MKIV under control?
Old 08-28-2012, 06:58 AM   #114
CSL323
My Ride: 330Ci
Ooo and I forgot one thing to suggest... As a general indicator, could you implement something on the software that would tell us whether or not an SD card is present on the board? Would remove the guess work of whether the SD card slot is soldered on properly. Another great feature would be using the Kracker as a USB mass storage device at a later release
Old 08-28-2012, 08:02 AM   #115
lsteg
My Ride: 2001 330ci
Can't you do that already with the SD cards? You can get ones that are 64gigs now-a-days. How much more space would you want? If anything going to USB 3.0 would be the best upgrade because of the transfer and read speeds.
Old 08-28-2012, 08:28 AM   #116
CSL323
My Ride: 330Ci
I think you've misunderstood me... What I meant was it'd be great to use the kracker as a device so that when you connect it to your pc, you can access and edit the files on your SD.
Old 08-28-2012, 08:38 AM   #117
lsteg
My Ride: 2001 330ci
Seems like a lot of extra work that can be solved with an SD reader that comes on most newer computers or an adapter that cost maybe $15.
Old 08-28-2012, 08:54 AM   #118
CSL323
My Ride: 330Ci
It is a lot of work and I do already have an adapter but it wouldn't be too bad of an idea someday though. It'd be nice to have a "SD CARD INSERTED" indicator on either the kustomizer or as an LED indication in the next release
Old 08-28-2012, 09:04 AM   #119
lsteg
My Ride: 2001 330ci
Indicator light - perhaps
transfer data via the Kracker - unnecessary
Old 08-28-2012, 10:16 AM   #120
ptrcd003
My Ride: .
Does anyone know if the turnsignal is accessible to program? I'd like to activate the one-tap for 3 blinks of the turnsignal.
ptrcd003 is offline   Reply With Quote
