Old 07-23-2012, 03:48 PM   #1
TiAg323ci
My Ride: 2000 323ci
Bad gasoline
I went to fill up this last weekend and I had about 1/3 of tank left. filled up with 93 octane and went about 20 minutes down the road. I started to feel a little hesitation in the car at lower speeds. The next day I started up the car and it threw the check engine light and the car ran rough. I went and put a bottle of seafoam in and drove it about 40 miles. I used about a 1/3 of the tank and went back to fill up at a different station with 93. We had flash flooding rains in Charlotte the day before I filled up and am thinking some of the rain might have got into the underground tanks at the gas station. The car is running rough but runs - do I just run the gas out of the tank? Would a little bit of water hurt anything?
Koni FSD's | Eibach Pro Springs |Staggered 19" VMR 710's | Hotchkiss Sway Bars | BMW Performance CF Strut Bar | Meyle HD Control Arms, RSM, Diff. bushing | Powerflex FCAB, RTAB| Brembo Sport Slotted Rotors + Akebono Euro Ceramic | Simota CF CAI | Conforti Shark Injector | Stewart Water Pump | M3 front and rear spoilers | Depo smoked front/side signals, Eagle Eye smoked LED tails | ACS interior trim/pedals | UUC Rob Knob 5 & floor mats |
TiAg323ci is offline   Reply With Quote
Old 07-23-2012, 04:13 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
Water will sink to the bottom of the tank, so it will get sucked out first. It will make the car run poorly, and it ought to throw a check engine light. If the quantity is small, then it should pass relatively quickly, and the car should clear itself up in short order.
Old 07-23-2012, 05:05 PM   #3
jasonbimmer
My Ride: 2001 BMW 330xi
get some Heet or dry gas from walmart. its basically pure alcohol and it absorbs the water.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-06-2012, 11:18 AM   #4
NCJunglist
My Ride: 06 BMW M3 Comp Pack
DONT USE DRY GAS - the alcohol attacks the contacts in the fuel pump - then you will be USCWAP. PM me, I'm in Charlotte NC and can help you out.
NCJunglist is offline   Reply With Quote
Old 08-06-2012, 11:29 AM   #5
jasonbimmer
pretty much all gas stations have ethanol in their gas, so whats your point?
besides its only 16oz in 16gal, not even 1% compare to the federal 10% ethanol.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
