Old 08-02-2012, 01:14 PM   #21
Grande D
My Ride: E36 M3
SAE and STD isn't dyno manipulation- they're just different correcting factors. I was told by a dynojet operator that to make the SAE falsified in any way you have to steam water around the weather station, or something to that effect.
Now what the difference is between dynos 1-2, 3-4, and 5-6 I'm not sure. Care to explain?
It will change your life!
Old 08-02-2012, 01:44 PM   #22
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
they are just correction factors and if the customer doesn't know what the data is well the dyno operator will use it to his advantage to get return business by giving his customer a higher reading dyno sheet, high numbers = happy customer, He would manipulate the dyno sheet. Sure he could explain what it all means but the customer is happy with a high reading dyno sheet.
And yes, where the weather station is placed in the room will play a role in the numbers because it will effect the weather readings a dyno uses for its correction factor. I personally played with this in the old shop I ran to see what would be the best placement of the tower.
Dynos 1-2 are Uncorrected
Dynos 3-4 are SAE
Dynos 5-6 are STD
Dynos 1-3-5 are smoothing at 0
Dynos 2-4-6 are smoothing at 5
All those dyno sheets are of the same run and 6 different numbers. From 405whp to 423whp.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 08-02-2012, 02:04 PM   #23
jared_wiesner
My Ride: 1999 328i (M54b30)
Edited****
NIVO,
The fact that the before tune numbers line up almost perfectly with what I would estimate the engine to be making at the flywheel and the fact that dyno dynamics specifically states the number is a flywheel number...
I'm still thinking its an estimated flywheel number.
Quote from this website: http://www.performancevauxhallshow.co.uk/2012/02/20/mobile-rolling-road/Dyno Dynamics rolling road
"measured flywheel figures are claimed to be within one or two percent of engine dyno figures, In addition to the power and torque figures, you can get an overall idea of how well your engine is performing, how it could be improved and any potential issues it may have"
The dyno being spoken about is a dyno dynamics wheel dyno (check the website if you don't believe me), clearly they are just estimating engine output based upon wheel numbers.
jared_wiesner is offline   Reply With Quote
Old 08-02-2012, 02:06 PM   #24
Grande D
My Ride: E36 M3
So dyno smoothing changes horsepower? Lolwut... I don't remember that from when I was using winpep or whatever it's called. That may be the case... but the biggest difference in the smoothing seems to be less than 1hp.
By the way a lot of what you're doing is repeating what I said.
Correction factors are not dyno manipulation. Dyno manipulation (to me) is a manipulation of the actual run.
Old 08-02-2012, 02:09 PM   #25
NIVO
Originally Posted by jared_wiesner View Post
NIVO, I'll take your word that you know about dyno dynamics machines when you say they are not providing flywheel horsepower numbers.
However, the fact that the before tune numbers line up almost perfectly with what I would estimate the engine to be making at the flywheel and the fact that dyno dynamics specifically states the number is a flywheel number...
As I mentioned, I can drive over there and dyno my car on that very same dyno.
Mustang Dyno I did 205whp/193wtq. All it will prove is what their corrections are set to that is all. If the car pulls near 235HP then their data is hand entered to closely match the wheel horsepower up to what flywheel horsepower would be. On those dynamometers that can be done.
Old 08-02-2012, 02:11 PM   #26
jared_wiesner
re-check the post you quoted, I edited it.
This is what I've been saying all along. They are likely literally adding somthing like 15-16% to approximate Flywheel numbers
Old 08-02-2012, 02:15 PM   #27
xixixi
Banned User
My Ride: 01 330x-xi
Everyone with half a brain knows wtf is going on here. I think this is hillarious and a pure troll thread. I enjoyed this thread, until it was taken seriously.
Old 08-02-2012, 02:17 PM   #28
jared_wiesner
Haha sorry to ruin your fun, it was hurting me inside to watch.
Old 08-02-2012, 07:05 PM   #29
Grande D
My Ride: E36 M3
I might beat you to it with the Epic tune (dyno that is). What'd you pay for it? Can you PM me?
Old 08-02-2012, 07:29 PM   #30
Steven747
My Ride: 05 330ci
It's only 300 bucks for a custom dyno tune from Bren fyi
Old 08-03-2012, 08:13 PM   #31
reggid
My Ride: .
guys, the dyno is reading flywheel hp as shown on the screen which is whp with a correction factor to account for drivetrain losses where dynodyanmics essentially use a fixed percentage of ~20%. This is actually a fact despite what others have said
the dyno only measures whp but you can get either the whp or the flywheel hp (approx whp/0.8) printed/ shown on screen.
it is also worth noting that the operator can't manipulate the data in dyno dynamics "shootout" mode other than IAT (should be shown on graph so cheating is obvious) and strapdown, tyre pressure, handbrake, A/C etc which you cant tell from the graph and can be done on any other dyno type. In non shootout mode the operator can scale the results by whatever he likes
it is very commonly used in europe and here is a random plot showing the "flywheel hp" and the "whp" where the run is the same but a fixed % correction is used.........
So the numbers on the original post are estimated flywheel hp not the more traditionally used WHP period..........
reggid is offline   Reply With Quote
Old 08-04-2012, 06:25 AM   #32
Grande D
My Ride: E36 M3
20% drivetrain loss?! Holy shiit.
Old 08-04-2012, 10:36 AM   #33
rkneeshaw
My Ride: 330i ZHP
Bottom line is those numbers in the vids on youtube are bull. And for an operator to try to post estimated flywheel numbers instead of at-the-wheel numbers is misleading and a bit shady.
I don't care what the arguments are, those cars are NOT making 260hp at the wheels. Not even close. Maybe 215 tops.
It would be nice if this tuner posted legitimate dyno charts that show at-the-wheels numbers, before and after his tune. Then we may talk.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 08-04-2012, 03:33 PM   #34
SH4DY
My Ride: '04 330Ci
Yes, those numbers seem high but I never saw how he was tuning the cars (what software?). shows OBDII for some 04 and BDM for 04-05... maybe one of the lucky few to get a pre-release shark edit or however else AA, Bimmerworld, etc are tuning the stock DME.
SH4DY is offline   Reply With Quote
Old 08-04-2012, 06:56 PM   #35
reggid
My Ride: .
in a market where WHP is the norm it is misleading whether it is deliberate or not is another matter. In Europe it is the norm though......
i find it odd that the torque gains are almost the same across the whole rev range which is suspicious in itself
the 20% used on dyno dynaimcs is not calculated using coast down losses either like some other dynos do e.g. Dastek , it is just a fixed correction that the software people at dyno dynamics came up with so that the new vehicles run on the dyno make about what the factory says. IMO it is a BS number but you can justmultiply by 0.8 to get the whp.
Old 08-05-2012, 12:05 AM   #36
jared_wiesner
Technically multiplying by .8 won't bring you back to percent less. 20 percent of 100 is 20. 20 percent of 120 is 24... See the problem.
Multiplying by .833 should get you closer.
Old 08-05-2012, 09:43 PM   #37
reggid
My Ride: .
if
BHP = est engine hp
WHP= hp at wheels
in the graph i showed WHP/BHP=0.80
therefore
WHP = BHP x 0.8
i call this 20% losses
BHP = WHP/0.8
so multiply WHP x 1.25 to get BHP in dyno dyamnics logic
Old 08-05-2012, 11:47 PM   #38
jared_wiesner
Ah, didn't catch that in the graph that you had a whp and bhp version. So ya if .8 is the correct number to multiply by to get whp, it means they were pretty much using a 1.25 correction factor. Which as you say is 20 percent losses from bhp or 25 percent gain from whp.
Old 08-06-2012, 03:50 AM   #39
reggid
My Ride: .
we are all to blame for this nonsense, people want dynos that spit out big numbers and thats what the dyno people deliver..........
i'll also add that WHP vs BHP can be determined from the graph, if it says "flywheel power" or has an S as in "S_Hp" and similar for torque then it is corrected by this made up number.....
Old 08-16-2012, 06:31 PM   #40
DarkJoker
My Ride: 01 330ci
the second video is my car and its flywheel rated
hopefully soon ill get on a dynojet
to give "actual" rear wheel numbers
DarkJoker is offline   Reply With Quote
