Old 08-02-2012, 07:39 AM   #1
Grande D
My Ride: E36 M3
Question So I Hear Our Stock Catalytic Converters are 400CPI... Question
First of all, can anyone verify that this is correct? Are the non-M headers 400cpi?
And this is really reaching, I wouldn't imagine anyone flowbenched the stock cats at any point? I'm looking at race cats.
Third question, 400cpi- does that mean 400cpi per cat? For example Supersprint says their race cat section one is 200cpi, which according to M3forum means there are two 100cpi cats, for a total of 200cpi. Is that how the stock manifold works? Is it two 200 cell cats for a total of 400cpi?
TIA!
It will change your life!
Old 08-02-2012, 02:41 PM   #2
jared_wiesner
My Ride: 1999 328i (M54b30)
TIA!
I have been wondering the same thing. I would really like to know the answer to this if someone else can chime in.
jared_wiesner is offline   Reply With Quote
Old 08-06-2012, 09:21 AM   #3
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
TIA!
If the car has 400cpi OEM catalytic converters and you go to a higher flowing 100 cell per inch race cat the car might throw a light. I have seen these many times. 200 cell is mostly used when you want good sound absorption but yet still flow better then OEM and not throw a light. I myself have a 200cpi metallic substrate catalytic converter I will be using for my car.
I highly doubt that the factory catalytic converters are 200 cpi each. more like 500-600cpi as companies like Porsche, Ferrari etc use 400cpi cats too. I have replaced a few of those with performance versions and they were not 200cpi even on Porsche turbo model cars!
I would do 200 cpi metallic substrate spun cats if you can.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 08-07-2012, 03:12 PM   #4
Grande D
My Ride: E36 M3
Random Tech would be my choice, cost vs performance. I hear HJS might be even better. MBS is a left field alternative. I know 100 would throw a light, I'm just wondering whether 400cpi means 200+200, or 400 and 400.
Old 08-07-2012, 04:14 PM   #5
NIVO
the M3 is a high output vehicle and other manufacturers use the 400 cpi cats as their high flow but yet emission friendly. I am sure that the factory M3 cats are considered 400cpi each.
A few years back we did testing on Random Tech metallic substrate 200cpi, Mil.Spec 100cpi, Magnaflow spun metallic substrate 300cpi, Eastern Cat metallic substrate 200cpi.
In order of performance:
Mil.Spec - $179 - 434whp
Eastern Cat - $80 -427whp
Random Tech - $255 -421whp
Magnaflow - $190 - 407whp
Since the testing I have used the Eastern cats for daily driving with some performance, I remove them for the track with a Vband set up. Previously I have used Mil.Spec and Random tech. I chose based on testing at the dyno I ran.
I attached a picture of one of the set ups we used during testing. Don't quote me on this but I think it is the Mil.Spec on the picture.
Other pic is of us having fun on the dyno testing this stuff.
ID:	463959   Click image for larger version
Name:	Cat Dyno test.jpg
Old 08-08-2012, 01:47 PM   #6
Grande D
My Ride: E36 M3
Nice! Great info. How about the durability of the Eastern Cat? How does it "handle" the OBD-2 light saga compared to Random Tech and Magnaflow if you know?
Old 08-08-2012, 02:11 PM   #7
NIVO
Well the higher flow through the cat will make the secondary Oxygen sensors thik that there is no cat there thus throwing a light, this is very common with the 100cpi cats. rarely does it happen on 200cpi on up. Using the Mil.Spec 100 cell cat the 4 out of 7 cars I know have passed emissions. I decided to go with the 200cpi myself because in mass they are strict like in Cali.
Here is a test from the Evo guys:
Ceramic highflow vs metallic substrate mil.spec, gains 14whp, ceramic is dotted lines
Here is an owner that wanted to go from test pipe to 100cpi cat (mil.Spec)
Lost 5whp and 11wtq. Test pipe is dotted lines
Old 08-08-2012, 02:35 PM   #8
Grande D
My Ride: E36 M3
What about durability? Estimate mileage before failure? Mostly for street use- some track.
Old 08-08-2012, 02:57 PM   #9
NIVO
Well I know that on my Z cars and other cars that I have used spun metallic substrate cats from random tech, mil.spec, eastern catalytic, well they all worked and no issues at all even with rich mixtures. I have a few Evo buddies with over 450whp with the Eastern Cat and no issues. that also goes for the Mil.Spec cat.
Metallic substrate cats flow a bit more the ceramics and can withstand the heat from diesel and turbocharged high EGTs.
for a daily driver it will last longer then OEM ceramic cats. I haven't personally seen any metallic spun high flow cats fail. That is all I will ever use to replace OEM units.
Old 08-08-2012, 03:51 PM   #10
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
That's some good information.
Old 08-09-2012, 05:06 PM   #11
aggieE46
Keep it clean
aggieE46's Avatar
I started up my car today with no catback on. With stock headers and no exhaust it's quieter than my car was with Techniks and headers.
