Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 12-05-2012, 09:43 AM   #41
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
OK...screw it.
I am way too paranoid to worry about these lion batteries.
However, I do love the brightness of the flashlights.
But I really want something to throw in the 72 hour bags, cars, etc.
The answer? New Cree T6 lights that can take AAA or 16850.
They are just a tad thicker and use an adapter tube for the 16850.
At $20 each, AAA battery adapter flashlights with the CREE T6 XML LED seem to be the answer for me.
They can use the 18650 or 3 or 4 AA batteries.
AAA batteries have a 5-10 year shelf life now and they DON'T EXPLODE!
At 4.5v the AAA start out with more voltage than an 18650 at 4.1-4.2 so they should be just as bright.
Of course, the AAA wont last as long for run time (should be around 60%), but you can buy a ton of AAAs at ($.30-.40 each) for the price of good 16850s and charger.
Maybe I can find a AA version which would last 70-80% as long.
My piece of mind is priceless.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 12-05-2012, 02:24 PM   #42
mkodama
mkodama's Avatar
Yeah, if you want shelf life, alkaline is hard to beat.
Old 12-05-2012, 02:30 PM   #43
GlockMan
GlockMan's Avatar
It just solves a lot of problems if you are using them for emergencies and not patrolling or something.
I found AAA and AA Duracell or Energizers for like .25 each.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 12-05-2012, 05:53 PM   #44
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
Since we're on the discussion of batteries for flashlights, everyone needs to be careful of lithium batteries. If you buy lithium batteries for use with lights or optics, make sure to only use batteries made in the US, and batteries made for use with the gear you're using. There are numerous incidents of Pakistani and Chinese made lithium batteries spontaneously combusting inside of weaponlights and optics. They are poorly built, and do not have circuit designs that will protect against overheating or shorting.
In addition to this, light and optic manufacturers have stated that you should not use photo lithium batteries in their products. Photo lithium batteries have a different cycling and discharge rate (or some kind of issue similar to that) that is designed for surges of current. Weapon light batteries like those from SureFire and Streamlight are designed for constant and consistent power output.
Besides this, photo lithium and normal lithium batteries are expensive. Why buy them when you can buy SF or Streamlight batteries IN BULK for a lot less?
Also, when you are storing lithium batteries, do not allow them to move around loosely. They should be in a container or compartment that prevents them from moving around. This is another cause of batteries catching on fire.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 12-22-2012, 04:52 PM   #45
GlockMan
GlockMan's Avatar
UPDATE:
I have ordered a total of 5 China type flashlights off of eBay; each using the CREE XML T-6 LED. It blows my mind how much light these things give out.
The first two of them use the pipebomb 18650 battery. After learning more about these (JonJon) I started my search for a similar type using regular batteries.
They are few and far between but I found some! At under $15 each, I bought three different models from three different sellers on ebay. All use 3 AAA batteries (or 18650) and the CREE T6 LED.
Anyway, they rock! Each is a little different.
1. I like the best, but does not fit 1" rings for pic rail, superwide solid beam, no halo, but the rear button sticks out and not protected.
2. I like second best, fits rings, but 1 out of 2 was defective (slide loose for focus, did come on though)
3. I like third best due to beam not as wide as #1, but it has a clickable focus, and is the unit is the smallest
All three have adjustable focus, strobe, and rear controls.
Anyway, at 4.5v for 3 AAAs, batteries should last decent time (like an hour) lsince the LED works down to about 3v.
I tried to find a reasonable Fenix version that used reg batteries. Only a couple of models and they are waaay overpriced for the same LEDs ($250). I am sure the build quality is better, but at 10-15x the price, it just gets silly.
What I do not understand is why someone can not make a $50-$100 light that has 3 T6 leds that run off of 3 D batteries. Its so simple. 3 Ds = 4.5v and as much as 3000mah. Run the 3 LEDs in parallel, so each wants 3-4.5v and the standard circuit driver has 3 output levels to save batteries.
You would get hours off the D cells and a ton of light dim-able down to normal.
1. 2.
3.
Amazon has AAA Duracells for $.53 each!
http://www.amazon.com/Duracell-Coppe...7&keywords=aaa
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 01-23-2013, 07:30 PM   #46
iwannagofast
My Ride: 01 330ci
Send a message via AIM to iwannagofast
Juat got 2 in from amazon that I ordered... the first one is 300 lumen and is bright as shyt. Second I need a battery for but its supposed to be 900 lumen... both where below 25 bucks each with free shipping
Sent from my SPH-L710 using Bimmer App
ID:	487455   Click image for larger version
ID:	487456   Click image for larger version
xbox live: stopthisfall
iwannagofast is offline   Reply With Quote
Old 01-23-2013, 07:31 PM   #47
iwannagofast
My Ride: 01 330ci
What 18650 battery should I buy... all of them have bad reviews lol
Old 01-23-2013, 07:39 PM   #48
GlockMan
GlockMan's Avatar
That is why I bought ones with AAA adapters.
48 pack of AAAs at Best Buy is $11 right now.
Each light takes 3.
You have to find a light that uses 26650 batteries for the AAA adapter to work.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 01-24-2013, 01:14 AM   #49
learthworml
mod-er-at-or-er
My Ride: 2011 Tundra Crewmax
I use Fenix lights. Cheaper than Surefire but still great quality. I have one mounted to my AR and have shot thousands of rounds with it mounted. The TK12 still works perfectly. Fenix gets my vote!
mods
Kore Fox coilovers w/ 2.5" front lift , Fox Rear piggy backs w/ 1" rear lift, 305/65 18 BFG at/ko, TRD front Skid plate, console vault
SQ sound system
Seas Nextel Mids, Focal Utopia Mids, Focal BE tweeters, JL Audio 13tw5, Alpine PDX-4.150, Alpine PDX-1.600, Audison Bit One processor, Pioneer z150 hu
learthworml is offline   Reply With Quote
