Old 08-03-2012, 04:32 PM   #1
imthiazah
My Ride: 2002 325ci
Angel eyes wont turn 'Always on'
Hi,
I installed the angel eyes two weeks ago and it worked fine for a little bit with the key in position 2, after that it just wont work. The lock/unlock feature still works though. My connection is all perfect, checked it several times. I have been in touch with khoalty (thats where i bought them from) and they have been very helpful and even shipped me a new harness. Even that gives me the same problem.
I checked the 12v wire using a voltmeter and it outputs correctly. Now i know i couldnt have blown a fuse.
Anybody have an idea what could it be?
imthiazah is offline   Reply With Quote
Old 08-03-2012, 04:37 PM   #2
Crespo5190
My Ride: 2001 325CI
So it just doesn't work when its on meaning the car running?
-Tony
Crespo5190 is offline   Reply With Quote
Old 08-03-2012, 04:41 PM   #3
imthiazah
My Ride: 2002 325ci
Yes, it wont turn on when the key is in ignition or when the engine is running.
Old 08-03-2012, 05:24 PM   #4
MercForHire
My Ride: M235i 6MT
There is two triggers wire taps for the angel eyes, one to the ECU accessory wire(on when the car is on), one to the passenger footwell light(on when interiors lights are on).
Old 08-03-2012, 05:33 PM   #5
Crespo5190
My Ride: 2001 325CI
+1 did you wire it to the ECU?
-Tony
Old 08-03-2012, 07:34 PM   #6
imthiazah
My Ride: 2002 325ci
Sorry for not being clear. Yes, I tapped both wires, the interior foot well and the 12v wire in the ecu box. It worked worked well for a while. Then I could see it flickering while driving and then it died. I am not sure if I blew a fuse.
The interior lights and accessories work perfect..
Old 08-03-2012, 08:45 PM   #7
das boots
My Ride: '90 M3 & '05 ZHP
Re-check all of your connections. Even on the ECU. The splice connector might have come lose. Make sure it cuts through the insulation. Test for voltage output.
Lawrence
BMW CCA San Diego Chapter #192742
'90 M3 - Garage Queen
'91 M Technic II Cabriolet 5 Spd - OOC
'99 M540i Touring - #2 Son DD
'03 530i 5 Spd - S.O.'s
'05 330 ZHP 6 Spd - Canyon Cruiser
'09 328i 2 Dr Step - #1 Son's DD
'03 Nissan Frontier Crew Cab - My DD & Range truck
das boots is offline   Reply With Quote
Old 08-04-2012, 11:49 AM   #8
scrace
My Ride: 03.5 M3
Your ECU connection isn't good. I've had this problem, the wire you are tapping into for the footwell is thinner than the ECU wire. I had to use wire cutters to expose enough of the wire to make a proper connection on the ECU wire.
My problem was that my lights would sometimes work when I was driving and sometimes not, but always fine with the footwell
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-04-2012, 11:51 AM   #9
MercForHire
My Ride: M235i 6MT
Its cool for about a week then you turn it off.
Old 08-07-2012, 10:00 PM   #10
Crespo5190
My Ride: 2001 325CI
Man... This problem just happened to me two days ago. I was driving and hit a hole and when I got to a store I realized they were off. Right now I just checked the ECU box and everything seems fine. What ended up happening to your problem does it work fine now?
-Tony
Old 08-07-2012, 10:23 PM   #11
MercForHire
My Ride: M235i 6MT
how long have u installed it? Maybe the wires burned out from engine heat.
Old 08-07-2012, 10:26 PM   #12
Crespo5190
My Ride: 2001 325CI
I've had them for about 3 months I would say. I don't think its anything from the heat cause right after I hit the pot hole they just don't turn on when the car is on. Only when the interior lights are on is when they work... I'll probably just re-cut again for another wire on the ECU box.... It's just weird though...
-Tony
Old 08-07-2012, 10:27 PM   #13
MercForHire
My Ride: M235i 6MT
definitely a problem with the ECU wire. Redo it.
Old 08-07-2012, 10:38 PM   #14
HiHoBrian
My Ride: 05 M3
I had a similar problem. The ecu wire triggers the relay and the power comes through the fuse holder. The interior signal wire powers the modules directly to allow the dimming to work and is protected by the interior lighting fuse inside the car. My issue was a bad crimp connection of the wire going into the fuse holder of the angel eye harness. That caused flickering or intermittent lighting while driving,but they always came on with the remote feature.
HiHoBrian is offline   Reply With Quote
Old 08-07-2012, 10:42 PM   #15
Crespo5190
My Ride: 2001 325CI
Yeah ill definitely redo it tomorrow after work. Driving without angle lights doesn't feel the same. Hah. OP what ended happening with you? Did you fix your problem?
-Tony
Old 03-18-2013, 01:48 PM   #16
imthiazah
My Ride: 2002 325ci
Sorry for not updating this thread. There was a problem with the ground wire not being screwed tight enough. Who would have known that was the issue unless i went around trying my hand at everything.
Anyway thanks for the suggestions.
