E46 Convertible
Old 08-04-2012, 08:24 AM   #1
philund
My Ride: e46
Locked glovebox
Hi all
Can you help????
I have a 2005 convertible and the glovebox has locked itself so i cant open it.
Phil
Sent from my GT-I9300 using Bimmer App
philund is offline   Reply With Quote
Old 08-04-2012, 09:37 AM   #2
johnrando
My Ride: '06 330 CIC ZHP
There are a few threads about this, mainly the fix is tightening the screws inside the box to prevent this from happening again. I'm don't exactly know what the solution is to get it open if locked. I recall mine locked once and I just played with the key... put the key in the lock, force it left (or right), and try to open the box with the key in at the same time it's far left or far right. Try different depths too. Barely insert the key and gently do it, and if that doesn't work, push the key in deep and then turn it. It was frustrating but eventually it unlocked. Of course, make sure you car is unlocked.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 08-04-2012, 09:46 AM   #3
philund
My Ride: e46
Many thanks for the ideas ill give them a go.
Old 08-04-2012, 11:31 AM   #4
UntaM3d
My Ride: 05 ///M Convertible
Originally Posted by johnrando View Post
...... put the key in the lock, force it left (or right), and try to open the box with the key in at the same time it's far left or far right. Try different depths too. Barely insert the key and gently do it, and if that doesn't work, push the key in deep and then turn it. It was frustrating but eventually it unlocked...
...lol...sounds like losing my virginity with my first girlfriend ...
UntaM3d is offline   Reply With Quote
Old 08-04-2012, 11:34 AM   #5
philund
My Ride: e46
Ha ha
Glad you enjoyed it. But whats the answer
Old 08-04-2012, 11:49 AM   #6
tran330cic
My Ride: Estoril Blue M3 Vert
I think these convertible gloveboxes all have problems. Lot's of people searching for the solution. Plus, my 330cic had the same problem with the glovebox.
My new M3 vert glovebox only unlock with the key. I have to turn the key to the left and pull the little handle to open. I need to find the solution to this glovebox issue too.
tran330cic is offline   Reply With Quote
Old 08-04-2012, 11:54 AM   #7
philund
My Ride: e46
Cheers mate and best of luck keep me posted if you find a solution
Old 08-04-2012, 06:49 PM   #8
ragtop69
My Ride: 2004 bmw 330 conv.
I had the same problem. Slowly pull on the latch and at about 3/4 pull it should open. If you pull the latch fully it won't open. Once open tighten the screws
ragtop69 is offline   Reply With Quote
Old 08-05-2012, 12:37 AM   #9
cityjohn
My Ride: 2001 M3
1. As everyone else has said, turn left and right whilst pulling on handle. May have to turn more than usual.
2. Once open, tighten the two phillips screws holding the latch to the glovebox door. Even if they don't feel loose, tighten them -- even a little makes a big difference in the latch being easy to open. Good luck.
cityjohn is offline   Reply With Quote
Old 08-05-2012, 12:44 AM   #10
E92M
E92M's Avatar
My Ride: '08 ZCP M3 | '03 R6
...... put the **** in the *****, force it left (or right), and try to open the ***** with the **** in at the same time it's far left or far right. Try different depths too. Barely insert the **** and gently do it, and if that doesn't work, push the **** in deep and then turn it. It was frustrating but eventually it unlocked...
Gotta hold on to this gem.
-Chris
E92M is offline   Reply With Quote
Old 08-05-2012, 03:35 AM   #11
johnrando
Trust me, I was thinking what everyone is saying while I was typing it, and I actually changed some words so it wouldn't sound so blatant! I really was describing the lock but definitely loling at the double entendra.
Southern California
Old 08-08-2012, 08:30 PM   #12
tran330cic
I checked the glovebox today and no more locked glovebox!! I open the glovebox and unscrewed the two back screws. Inspected the lock, springs, and latch. Everything looked okay and I put it back together and tighten the two screws and now it unlocks, locks, and open great!!! Check your two back screws to see if they are loose. Good luck!
Old 08-08-2012, 11:11 PM   #13
ragtop69
Glad you got it fixed
Old 08-09-2012, 01:24 AM   #14
philund
My Ride: e46
Glad to hear yours is ok unfortunatly mine is still locked having tried everything. Ill keep trying fingers crossed.
Thanks again
Old 08-09-2012, 12:08 PM   #15
Offshore24
My Ride: 2002 BMW 330Ci
Mine does not work 100%. I find if I push the door in with one hand while gently prying open the handle with the other I can get it to unlatch. I've tightened the screws so many time I think they need locktite or replacement.
Offshore24 is offline   Reply With Quote
Old 08-09-2012, 01:29 PM   #16
cityjohn
My Ride: 2001 M3
^ good call. I do this too! If you simply pull the whole thing down with the handle (like every other car in the world) it will frequently not open. But holding the door securely until the latch is all the way pulled does work. It's just become an instinct with me.
Old 08-10-2012, 04:50 PM   #17
jimvideopro
My Ride: 2006 330CiC
Popping the power locks a few times while turning the key has helped me a few times. I'm about to disconnect the power lock on the glovebox....
jimvideopro is offline   Reply With Quote
Old 10-07-2012, 06:24 PM   #18
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Just picked up a vert. Glovebox is locked. Gonna see what's up with it tomorrow.
So u basically just keep trying with the key till it opens?
Do you ride a sportbike?
Old 10-07-2012, 07:31 PM   #19
RKiepper
My Ride: 1999 E46 328I x2
There's a power lock on the glovebox?!
RKiepper is offline   Reply With Quote
Old 10-07-2012, 08:03 PM   #20
Snik
Snik's Avatar
I THINK it has a setup where when u lock the doors of the vert. It locks the glovebox. Kinda like the gas door.
Not entirely sure tho.
