Old 08-04-2012, 06:07 PM   #1
TheSinner-
My Ride: 325 Ci - 2001
Exclamation Sidemirror wiring help - 5 wire > 9 wire
i dig for 2 hours now and still found nothing that really can help.
so, coupe - 2001.
i bought a mirror and it has a 5 pin connector with 5 wires
on the car.. there is a.. 10 pin connector fit with 9 wires inside
I cut the connector and i started to match the wires. i only sorted out UP and LEFT but nothing more, after 3 hrs of cursing and swearing.
does any of u have any ideea how to deal with this sh***?
i found out that the 10 pin connector is because i have memmory option on the car, the 5 pin connector i have on the mirror is that because the car that was taken from had'nt got this fucntion.
is there a way to.. to this ?
NO RIBBON btw. so get this out of the ecuation. thanks
BMW 325 Ci (for bad weather use)
Ducati 748 (race use)
Ducati 749 (road use)
TheSinner- is offline   Reply With Quote
Old 08-04-2012, 06:24 PM   #2
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
Technically the best case scenario would be to get full mirror control (up - down - left - right) but without the 'memory' option as the lack of wires coming from this 5-pin mirror doesn't have the additional 4-pins needed to read the mirror position for the memory function.
So it is your call on what you want to do. Full function without memory or get another 9-pin mirror.
Sucks you ran into this road block. Good luck!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 08-04-2012, 06:27 PM   #3
TheSinner-
i wanted to find out if there's a way of making this mirror to work with what i have now, i 'll renounce to have memory on it but at least to be fully adjustable from the switch.
Old 08-04-2012, 06:53 PM   #4
jgold47
My Ride: 2004 X5 3.0
Did you try the wds? Google BMW wds. Should sort you out as to which color is which...
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 08-04-2012, 07:05 PM   #5
jgold47
my about me link
mirror, wiring
