Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Old 08-05-2012, 10:12 AM   #1
lycanTreo
My Ride: 2000 323ci 2009 135I
Help car won't start.
As the title states the car wont start. Well I tried starting the car and all got was a click sound and heard the fuel pump humming in the back. I checked the battery connections and even tried giving it a boost no luck. the battery is only a couple of months old so i know it's not the battery. I'm starting to think is the starter but I don't know the were the starter is. Please help.
Let me help you search this site quickly! Replace the word TEST with what you need! (TRY IT!)
lycanTreo is offline   Reply With Quote
Old 08-05-2012, 10:16 AM   #2
zhenkaaaM3
My Ride: Fst'r then your e46
Its the alternator. If your not getting 13.5-14.2volts when thr car is running, then you know why. Luckily i have a manual so ill push the car, pop the clutch n then im outtie.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 08-05-2012, 10:27 AM   #3
lycanTreo
These are the times I wish I had a manual. Is there a good DIY in how to replace it the starter that you know off?
Old 08-05-2012, 12:36 PM   #4
zhenkaaaM3
Starter is a pain in the ass to do. Pull out your battery and have it fully charger. See if it starts after that.
Eugene
Old 08-05-2012, 12:39 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Yes, try a charger or just boost it for longer...with donor car revving at 1500-2000 rpms for maybe 5 mins. Boost under the hood too...and check the cable under + terminal and make sure both your battery cables are tight. Pull up on them...sometimes you tighten them, but the terminals are too small for our cables...so they're really loose. They do make spacers if you need.
Don't give up on battery just yet, even though it's new. Might just have been many short trips and no long ones to restore your battery's power. Pretty common.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-06-2012, 11:39 AM   #6
Motorcepts
Past Site Sponsor
My Ride: BMW
sounds like a starter. ANy check engine light? put a scanner on ...
if you need any help over the phone feel free to call us 347-644-5363
Leo
Motorcepts is offline   Reply With Quote
Old 08-06-2012, 10:18 PM   #7
myOwnM3
My Ride: 00 S4
2nd on the starter. if you getting ~12v on the battery while cranking then your battery is fine.
myOwnM3 is offline   Reply With Quote
Old 08-07-2012, 06:49 AM   #8
dmax
dmax's Avatar
Unless there's a bad ground or the cable to starter is loose/corroded--it's the one under the + terminal under the hood. Undo it and check.
You can also do what many do...have someone tap the starter while you try cranking. If that does it, then it's definitely the starter.
Mangofy your E46!
