Old 08-28-2012, 12:32 AM   #21
Brinkley
My Ride: 99 328i, 07 z4 3.0
Originally Posted by BMWCaptain View Post
That is very rare to have a mechanical fan in addition to the aux fan for a manual transmission 328i.
Tour aux fan is in front of your radiator?
Not really I have the same setup, so do many others, early production 323/8s have the clutch/aux combo until they switched to electric fan only for manuals. We basically have the same as autos.
Brinkley is offline   Reply With Quote
Old 08-28-2012, 12:38 AM   #22
My Ride: 2016 Lexus
Part of the problem is that you didn't replace the entire cooling system.
The following should be checked:
there's a blockage in your radiator
thermostat stuck closed or partially closed
there's air in the system
aux. fan switch is not functioning
pusher fan is not functioning
mechanical fan is not functioning
All this is remedied by replacing the entire cooling system and performing a proper bleed.
Old 08-28-2012, 01:08 AM   #23
REKLESS ROB
My Ride: 2004 325ci
Head gasket?
REKLESS ROB is offline   Reply With Quote
Old 08-28-2012, 03:59 PM   #24
Elvin123
My Ride: 328i
The only thing haven't replaced is the radiator. I will be switching the clutch fan to the electric fan today, hopefully that will fix the problem
Elvin123 is offline   Reply With Quote
Old 08-28-2012, 04:08 PM   #25
zander271
My Ride: 6spd ZHP/5sp XI
How many mile are on your car? I think word is that ther radiators should be replaced at 150k.
Old 08-28-2012, 04:28 PM   #26
Elvin123
My Ride: 328i
I just recently passed 90k
Old 08-28-2012, 05:29 PM   #27
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
I am going to go out ona limb and say that your aux fan may not be working correctly. You mention your ac is not as cold.
When you have a cooling system failure like the expansion tank, you need to find the reason for the overheating. If your aux fan is not coming on properly, then your temp can increase especially with the ac on.
Here is a way to check it:
Turn your car on, ac off. Ck aux fan, should not be running.
Next turn your ac on, Aux fan should come on.
Next disconnect temp sensor in lower radiator hose. Aux fan should speed up to full speed.
If it works correctly, then it may not be your fan. But you have replaced most everything else in the cooling system.
Bleed, burp, bleed the system.
Do you have any oil in your coolant? Check your oil too. This would indicate a bad head gasket. You say you are not loosing coolant, so it is unlikely a bad head gasket.
BMWCaptain is online now   Reply With Quote
Old 08-28-2012, 06:58 PM   #28
BMWCaptain
I don't think it is as common on manual 3 series as you think. I have an early 323i manual and mine does not have the mechanical fan. I think you misinterpreted my statement. I said it was rare, I did not say it does not exist. Let say it was a few months where they had it. That makes it rare because a vast majority of them do not have the mechanical fan.
They also don't mention that setup in the bentley manual.
Old 09-06-2012, 04:34 PM   #29
Elvin123
My Ride: 328i
Turns out that after I replaced almost every component of the cooling system and the car still overheated. The only part that I didn't replace- the radiator, doesn't seem to be circulating well because as the upper radiator hose heats up the bottom hose and the radiator are still cold. I bought a new Behr radiator and my car will be all good by tomorrow. Hopefully
Old 12-14-2012, 12:40 AM   #30
NumbaOneNewb
My Ride: 2003 330CI Silver
on one note, I programmed a 1998 528 manual and it had a mechanical fan on it. It tripped me out. Anyways, Ive done my coolant bleeding with the car off, position 2, temp on 90, speed lowest, all vent options open, and the dial in the middle of center vents on all the way red and never had an issue. I'm also using prestone 50/50, after doing research through numerous forums and came to the conclusion that while BMWs coolant may be somewhat better, this stuff works and has been working for over 10,000 miles. No issues here.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 12-14-2012, 10:18 AM   #31
Brinkley
lol just saw this, you basically said what I said, if your car was produced before the switch, you got a clutch fan, after, an electric fan. Nothing rare or mysterious about it. Perhaps the bentley just assumes that if you have a bentley you can tell the difference between clutch/electric fans and just look at the auto for instruction.
Old 12-14-2012, 10:50 AM   #32
BMWCaptain
maybe you should read what I said!
I am not saying what you said!
You don't understand that the manual transmissions come with only an electric fan. If you have a mechanical clutch fan as well, then that is not typical. I do not have a mecganical clutch.
Please clarify this for all of us, So tell us what date ranges have the mecanical fan in addition to the electric fan on a manual transmission car.
Old 12-14-2012, 10:56 AM   #33
STORMER
My Ride: AA SC 98 M3
I can confirm I had a mechanical clutch fan in my 99 323. Production date was 11/98
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 12-14-2012, 11:00 AM   #34
Stinger9
My Ride: '04 330Ci
Think you got that backwards. Radators cost $150!
Old 12-14-2012, 01:11 PM   #35
Brinkley
Look dude. Early model manuals came with clutch fans, k? I don't get why this is such a big deal.
Old 12-14-2012, 01:44 PM   #36
STORMER
Again i can confirm my manual 323 came with one
360+rwhp
Old 12-14-2012, 02:16 PM   #37
Brinkley
Thanks, good looking m3 there!
Old 12-14-2012, 02:20 PM   #38
///MPR77
My Ride: 02 ///M3 Tri-Ped
My 2000: build 10/99 has electric fan.
Maybe just on e46 builds of late 1997 and 98 had the clutch fan.
Sent from my SGH-I727 using Bimmer App
Old 12-14-2012, 02:28 PM   #39
Brinkley
Yea probably something like that. I drive a 7/98 328, so I guess to most people I'm a VERY freaking early model. Anyways, I used to think I was special or something or had got ripped off, but it's just I have an early car.
Old 12-14-2012, 02:40 PM   #40
///MPR77
Was it originally purchased in Europe?
I know on RealOem it shows for 328i 9/97 as the earliest production month for US delivery.
Europe is: 4/97
Looks like it could it be a cooling package (Hot climate version) option, again just based on looking at realoem.
