E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
Anyone run these on their XI? 225/50/17
Picked up a set of 225/50/17 Michelin X-ice for an unbelievable deal. My ride is an 02 330XI, which currently has 205/50/17 Summer tires on it. I know what the manual states, and what the door jam states - 205/50/17.
My question is, is there any issues if I ran these 225/50/17 in the winter? Anyone run this size on their XI? Any rubbing or anything? |
#2 |
Should not be rubbing since I have ran 225 x 45 with no issues. Xi's are pretty immune to rubbing issues due to the added height.
#3 |
#4 |
You will be fine. Slight increase in ground clearance, slight loss in acceleration.
#5 | |
Less chance of me doing something stupid haha.Thanks for the info guys. |
#6 |
Cool on the Tires
I've been running 225/50/17 for 3 years without any problems at all
#7 |
My Ride: 03 325xi, 03 330xi
You will have a slight loss in overall acceleration, slight MPH error as the tires are larger in overall diameter, both of these are minor. Your biggest problem is that you will have DECREASED traction in the snow and ice, exactly what you bought the tires for. You will not experience as much loss in traction with an XI as you would in a rear wheel drive only, but these tires also have a wider contact patch. A wider contact patch (where the tire tread meets the road surface) is great for summer driving, however, for driving in snow and ice, you really want a small contact patch, thus putting more of the vehicles weight on each contact patch and letting the tire get the best bite and traction that it can get. Actually, the 225/50/17 isn't even a listed PLUS 0 size for your car, the true Plus 0 size for the car is 225/45/17.
#8 |
Hey, 325xittt, where in Reading? I also live in the Reading area, Exeter Township. I see some (or maybe just one) silver 325 xit running around.
#9 | ||
#10 |
^you're fine dude. Try and find OE rims on craigslist- don't buy steel wheels.
#11 |
#12 |
What they used to call a PLUS 0 (now usually just referred to as optional size for stock wheels) is 225/45/17 for your car. Slightly lower sidewall and slightly wider tread. For new steel wheels, you can try the Tire Rack............www.tirerack.com. There you can also see all the correct sizes for your car in 17", 18", 20", etc. And as I said before, running those 225/50/17 winter tires will compromise the ice and snow traction because of their tread/contact patch width (though not nearly as bad as on a rear wheel drive 330). Me, I would sell the tires for what you paid for them and get some proper snow and ice tires.
#13 |
^disregard that post.
Will they be the best in the snow? No. Will your xi still kick serious ass in the snow? Yes. I have 225 Hakka R's and 205 studded hakkas. Both are unbelievable in snow. |
#14 |
Not to threadjack, but I also have a 2002 xi that needs tires. But I was thinking of going with 225/45/17s. They're nearly the same circumference as the stock 205/50/17s. My question: will the stock wheels that currently have the stock 205/50/17 tires on be wide enough to accommodate the wider 225/45/17 tires? Anyone want to take a guess? I don't even know the stock wheel width. Is it 7 inches?
#15 | ||||
![]() You will have decreased traction relative to a thinner tire, not relative to your all seasons or even summers. Either way, it's not substantial enough to not get a steal. I run 225/45/17 all winter long and the Xi dominates snow. Quote:
Plus 0 sizes are wider tires without increasing the overall outer diameter. Quote:
#16 | |
Are you buying all-season or summer tires? |
#17 |
xi-xi, the 225/45/17 is the optional size to the 205/50/17s and will fit the stock rim with no problem. A great summer tire upgrade, a trade-off upgrade if using All-Season Tires (personally I don't believe in the All-Season tires as they are a total compromise), but a poor choice for winter/snow/ice tires (see above), though not as much a poor choice on an xi as on a rear wheel drive only BMW. If you want a good All-Season tire though, go for the Continental Extreme Contact All Season tires, one of the best choices out there for All-Season tires I think.
SamDoe1, didn't say anything about decreased tractive compared to summer or all season tires, DECREASED traction with the 225/50/17 snow tires in relation to even 205/50/17 snow tires, the wider the tread on snow tires, the decreased traction because of the increase size of the contact patch and less of the vehicle weight on the contact patch of a wider tire than a narrower tire. You are using 225/45/17s, that is a correct size (the true Plus 0 size) for your car (would I use them for dedicated snows, no, but that's your choice), and those are a bit different that OP's 225/50/17s that he got a good deal on. Like I said before, it isn't as big a lose of traction and control in snow and ice with the wider tires on an xi as opposed to a rear wheel drive BMW, but there still WILL BE a decrease. For the winter, get more slush and ice where I live than deep snow, I want the best traction I can get, so the proper narrower tread snows with slightly higher sidewall go on. Gives a bit more clearance for build up underneath, more weight and therefore more traction on the narrower contact patches. |
#18 |
Thanks for the responses! It's not really practical for me to have a separate set-up for the winter, so I'm going with All Season tires. I don't plan on any plowing through deep snow, but there is always a chance of inadvertently getting caught in a coating of some white stuff going to or from work. I understand the disadvantage of a wider tire in snow--yes it'll float-- but I don't think that's going to be a major problem. I anticipate snow driving to be minimal. I have a dedicated vehicle for bad snow. I also heard many good things about the Continental Extreme Contact--$125 apiece at Tire Rack. I know they're a compromise, but I think they'll be an upgrade from what's on the car now in decent weather.
#19 |
This info from a australian tech site:
Tyres, Grip and All That... Sorting fact from fiction in tyre physics By Dennis Jensen So many tyres; so many factors to consider! Do you go wider? Do you go for a lower profile? Do you increase your wheel diameter? What pressures do you run? The whole area is quite complicated, and the result is that there is a hell of a lot of misconceptions out there. What is needed is a primer to give some fairly solid grounding in the basics, so that informed decisions can be made. So, let's go through two of the misconceptions, and see if we can get an understanding of what actually contributes to grip - and what does not. Myth 1: Wider tyres have a larger contact patch than narrow tyres What actually influences the size of the tyre's contact patch? Is it the width of the tyre, or the profile? The simple answer that it is neither of these; the size of the tyre's contact patch is related to: * the weight on the wheel * the tyre pressure. For example, say that the weight on the tyre was 900lb, and the tyre pressure was 10 psi. That internal pressure means that each square inch of area can support 10lb, so, in this case, the contact patch will be 90 square inches. If the tyre pressure was 30 psi, the contact area would be 30 square inches, and if the pressure was 90 psi, the contact area would be 10 square inches. This has been found to be almost exactly correct for most tyres (the exceptions being so-called run-flat tyres, or tyres with extremely stiff sidewalls). For most other tyres, carcass structure will have an effect, but by far the major factor is tyre pressure. So, as you can see, the size of the contact patch of a tyre is *not* related to the width of the tyre - it is, in fact, proportional to the tyre pressure. What *will* change with the fitting of a wider tyre is the shape of the contact patch - it will get wider, but shorter longways. Myth 2: A larger contact patch = more grip Okay, most people will come to the conclusion that if you have "more rubber on the road" you will have increased grip. Sorry to say this folks, but to very close to 100% accuracy, the size of the contact patch is irrelevant. The actual grip that a tyre can generate is dictated by the coefficient of friction of the rubber compound used in the tyre. The higher the coefficient, the more grip which can be generated. The relation that is used is called Amonton's Law, and the equation is: F=uN, where F is the force generated, u is the coefficient of friction, and N is the weight on the surface considered (in our case, the weight on the tyre). So, if you increase the weight on the tyre, then the frictional force will increase as well, in proportion to the increase in weight on the tyre - but the coefficient of friction will remain the same. The level of grip of the tyre (forgetting about suspension niceties - we are only discussing tyres here) is totally dictated by the coefficient of grip of the tyre and the weight acting on it - not the area of the contact between the tyre and the road. Why Not Narrow Tyres, Then? So, I hear you argue, why bother with wide, low profile tyres at all? Why not simply have narrow, high profile tyres? The simple reply to that is heat (remember, we are simply talking grip here, not the niceties of handling finesse). The point is that, to get a contact patch of a certain size on the road, you need a certain portion of the tyre to be flat. Taking the contact patch to be basically rectangular (though it is actually partially oval in shape), then the area of that patch will be its length times its width. Now, for a narrow tyre, the contact patch will be quite long compared with a wide tyre. This introduces two problems for the tyre. First, to get that long flat section to give the required contact patch, the sidewall of the tyre needs to deform quite a lot. This deformation actually causes the bending and unbending the rubber of the sidewall as it flattens and then the tread curves again. This bending and unbending process results in a lot of heat being generated. (Think about bending and unbending a piece of wire rapidly, and how hot it gets as you do so. If you bend it less, but at the same frequency, less heat will be generated). Obviously, the more it needs to bend, the greater the amount of heat generated. The second relates to the length itself. There will be a greater percentage of the tyre tread in contact with the road than if the contact patch length were shorter; this reduces the amount that the tread can cool. Also, there is a greater percentage of sidewall at any given time that is actually under bending stresses, again resulting in less opportunity to cool. So, how much extra bending do you really get, and how much is potential tread cooling reduced? Let's take a theoretical example, and take a 155-width tyre compared with a 225 tyre of the same circumference. Agreed, this is an extreme example, but it will suit our point very well. Assume that the wheel/tyre-unloaded circumference is 60cm. Assume the tyre pressure is 30 psi, and that the weight on the wheel is 600lb, giving an area of 20 square inches (or 129 square cm). Assuming that the contact patch is rectangular, with the wider (225) tyre, the patch will be 5.73cm long, and with the 155 tyre, the patch will be 8.32cm long. Now, the circumference of the wheel-tyre combination is 188cm, so the 225 is heating for 3% of its cycle, and cooling 97%, whereas the 155 is heating for 4.5% of the cycle and cooling for 95.5%. So, you can see that the narrower tyre is generating heat 50% longer than the 225, and is not spending so much of its cycle cooling. Now, as far as heating of the tyre is concerned, simple geometry shows us that the 155 tyre bends by 0.29cm, and the 225 bends by 0.14cm. Now, assuming that the heating of the tyre is roughly proportional to the deformation, let's find out the results of all of this. We will multiply the deformation by the percentage of time the tyre sidewall is under stress, and divide this number by the percentage of time that the tyre is being cooled. Multiplying the resulting numbers by 100, we get a figure of 1.37 for the 155 tyre, and 0.43 for the 225. Dividing the 155 tyre's number by that of the 225, we find that the heat generation of the 155 is */3.2 times that of the 225!/* This is quite an amazing result, given that the 225 is only 45% wider than the 155. As a result on this increased generation of heat, and the reduced capacity for self cooling, the tyres need to be made of a harder rubber compound that is more able to resist heat. This harder compound will, of necessity, have a reduced coefficient of friction, particularly when cold. The tyres that are wider can have a softer compound with better frictional properties. Due to the reduced bending stresses, and greater cooling opportunities, the tyre will tend to stay within a narrow temperature range quite consistently, giving greater cold grip, while managing to have a reduced propensity for overheating. Obviously, this makes for a better performance tyre. On the issue of wheel size (the diameter, not the width), it is therefore clear that increasing the wheel/tyre diameter combination is beneficial. The reason for this is that the tyre will not have to deform so much to get the required contact patch length, and the percentage of the tyre tread in contact with the road will be less than for a smaller diameter combination. So, what about tyre pressure? Obviously, tyre pressure plays a very important part, but there are clearly limits on both sides of the tyre pressure equation. At the higher end, there is the maximum tyre pressure that can be sustained before there is damage to the carcass. At the low end, you don't want the sidewall almost collapsing, generating massive heat, and have the tyre slipping on the rim. So, you can play around with tyre pressures to optimise your set-up, but there are limitations. A simple way to find out approximately what pressure is optimal for your combination is to draw a chalkline across the width of the tyre, drive for a bit, and look at the wear pattern of the chalkmark. Wearing more quickly in the centre indicates pressure that is too high, and wear on the edges indicates too low a pressure. One issue to consider is that, for wet weather driving, despite what you may have heard, it is better to increase your tyre pressure, not reduce it. The reason is that there is a relationship between tyre pressure and the speed at which there is the onset of aquaplaning. In the Imperial system, the equation is 9 times the square root of the tyre pressure. So, if your tyres are at 25 psi, if you drive into a puddle that is deeper than your tread depth, you will aquaplane at 45 mph (72 km/h), whereas if your tyre pressure was 36psi, you would aquaplane at 54 mph (87 km/h). The advantages are obvious. As far as tyre profile is concerned, the main benefit is one of handling - the lower sidewalls give reduced sidewall deformation under lateral loading, which results in improved steering response and a more stable contact patch. Conclusion Summarizing, what factors are important in terms of tyre grip? Tyre width has no direct relation to the amount of grip generated; it is a secondary factor, and the width basically relates to cooling potential and so the tyre compound that can be used. The size of the contact patch has no bearing on the amount of grip generated at all, apart from the extreme of where the compound is getting so hot that it no longer acts as a solid (and therefore doesn't follow Amonton's Law). The tyre pressure has no direct bearing on the level of grip (apart from aquaplaning), but it does have a bearing on the heating and cooling characteristics of the tyre. Having a lower tyre profile gives improved handling through reduced sidewall stress and improved contact patch shape stability. Did you enjoy this article? Please consider supporting AutoSpeed with a small contribution. More Info... Share this Article: |
#20 | |
The rims even have BMW lettering right on them so it's OEM equipment. If not to use steel rims, from what other vehicles will a rim fit the bimmer? I can't seem to locate any el-cheapo rims around me that are in $hit shape in order to be worth running for winter. |
