Old 08-05-2012, 06:47 PM   #1
Papa_e36
My Ride: e36 318is
m54b22 in e36
hi there, i currently have a e36 92 318is, and few days ago i got from a friend a complet engine m54b22 with all electronics, computer, gas pedal, infact a whole front end of the car...a z3 2002...
and i am wondering are there much problems to put in my e36...
because i dont have an ews neither the drive by wire throttle pedal...
so any advice is well appreciated
i have a complete car...why it cannot work? what sensors?
i have all the wiring, the key, the ews module, i wrote that in the upper post...
i have a complete donor car, its a z3 2002
so nobody nothing???
today i pulled out the gas pedal and tthe wiring i prepared, so that is sorted out,
i have the EWS module and the key and the key ring also prepared...next to do is to cut the wires i dont need and to find time to put the engine in...so any help about the wiring diagrams would be much appreciated...
i want this engine because it has 50000miles, and the engines here in my country all have over 150000, or more...so do you now understand whay i dont put 325 or 328 from e36 in my car...
i found here some ideas...this engine is the same as the e46 320ci
by the way, i need some photos of the ecu loom how it connects to the ecu, what plugs,where do they go...
Papa_e36 is offline   Reply With Quote
Old 08-08-2012, 02:51 PM   #2
Papa_e36
My Ride: e36 318is
i cannot believe nobody can help...
i need pinout on dme ms43 and on engine bay connectors of the e36, the x20 connector, or if anybody has an idea how to connect these two harnesses
