Old 08-06-2012, 03:36 AM   #21
farukh
My Ride: BMW 325i 2002
Originally Posted by Solidjake View Post
Yup right away I noticed it. I'm about 400 miles in already.
Slight fuel economy improvement, quieter idle, rpm doesn't bounce back when you're in neutral press the gas hard and let go, definitely more power in the low rpm range. I swear, I don't even push the gas so hard and it can hit 100 like that. Really is worth doing. I'm a believer.
Damn that's what I have now with these rpms... As soon as I let go of gas on lower rpms, car start jerking... You got the ones from beisian also?
farukh is offline   Reply With Quote
Old 08-06-2012, 03:54 AM   #22
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yup, it's the only place to buy them from.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-06-2012, 06:55 AM   #23
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The only real thing you need to pay attention to is the two 'opposite' turning bolts holding in the pistons. When you get to the pistons, be sure to loosen them by turning clockwise. I knew from the instructions that they were there, but in the 'heat of battle' I started to turn them the wrong way...saw the chains move and worried I'd affected timing...coz I didn't know. Called Raj and he assured me I was fine...and I was.
Very easy to do once vc is off. Get new vanos gasket from dealer...that's about it. Beisan's instructions are perfect!
BTW, I also didn't notice any difference.
Finally, as far as the comment about Raj making millions...I really doubt it. Even if Raj gets the seals for pennies on the dollar, he's not only saved us $$$, but he did ID the issue, source replacement seals, maintain a website, support us here online, and 'live' if you run into an issue. To save $250 or more, I think his pricing is reasonable.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-19-2012, 09:22 AM   #24
fanatic128
My Ride: 2005 330i
which step is this in the instructions..I think I'm gonna do this. I hear that rattle between 2-3 rpm. Thinks it's vanos.wish there was a good video on it. I'm more of a visual learner. The step "Remove 2 O2 sensor cable brackets at fuel rail." is a little confusing but maybe when I open it up I'll see what they are talking about. any help or gotchas is appreciated before I start..
fanatic128 is offline   Reply With Quote
Old 08-19-2012, 09:58 AM   #25
fanatic128
My Ride: 2005 330i
is that step even required? All the valve cover gasket video, I don't seem them messing with the ""Remove 2 O2 sensor cable brackets at fuel rail."
Old 08-19-2012, 11:02 AM   #26
farukh
You don't actually mess with the O2 sensors, you just move them out of your way with their wires and stuff.
Old 08-19-2012, 11:19 AM   #27
fiveightandten
My Ride: '03 330ci / '98 M3
O2 sensor brackets and cable are at the bottom seciton of the valve cover, not at the fuel rail. You just need to get the wires out of the way so you can get the valve cover off. Pull forward and up, it pops right out, then just disconnect the ground wire (8mm nut) and pull it out of the way. 10 second part of the process and nothing to worry about.
-Nick
fiveightandten is offline   Reply With Quote
Old 08-20-2012, 09:00 PM   #28
fanatic128
My Ride: 2005 330i
I guess I didn't research this enough but it seems that if I hear a rattle that I need the anti-rattle kit as well?
Replacing the seals will not get rid of the rattle? If I would of known I would of just spent extra money
on Dr.Vanos. I don't like the sanding procedure in the anti-rattle kit.
any suggestions?
Old 08-20-2012, 10:47 PM   #29
fiveightandten
any suggestions?
If you don't like the sandpaper method (I don't blame you), sell the seals in the classifieds and buy the Dr VANOS or VAC motorsports kit. IMO, it's worth twice the money to have a properly rebuilt unit. I used the VAC unit in my 330ci, and I used the Dr VANOS single VANOS unit in my E36 M3 a number of years ago. I can vouch for both being good products. I did the VAC unit in my 330ci recently, and it both quieted things down and give the car a noticeable boost in power.
-Nick
Old 08-26-2012, 07:09 AM   #30
fanatic128
My Ride: 2005 330i
I read in another forum that the Biesan allows you can get a better fit because you can customize the axial play
but of course as I mentioned you need to sand the washers yourself as needed. Does Dr Vanos
have more Axial play or do they come pretty well fit? I would think that they test the units from some type of model or
something.
Old 08-26-2012, 07:29 AM   #31
scrace
My Ride: 03.5 M3
yes, vanos seals made all the difference in sluggish acceleration.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-26-2012, 10:41 AM   #32
auto180sx
My Ride: '02 Steel Blue 330Ci
Originally Posted by MercForHire View Post
Not sure didn't notice much.
But the old seals were clearly plastic when they should be like rubber.
I fixed something I guess.
+1
I'm glad I did them though. I think I got a few 10ths better on my MPG, but other than that I didn't notice anything. It was a fun and easy DIY and I would still HIGHLY recommend everyone doing them.
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 09-02-2012, 07:52 AM   #33
Tim13E46
My Ride: 2003 M3
Doing this as soon as I get back to the states
Tim13E46 is offline   Reply With Quote
