Old 09-21-2012, 08:09 AM   #61
trizzuth
My Ride: 231k, 16yr old B3AST
Really like this idea D! Going to try this out as soon as I can.
trizzuth is offline   Reply With Quote
Old 09-21-2012, 10:15 AM   #62
My Ride: Lexus
Be careful, hip hop guy. Last time D had his passenger hold his hose out the window, the cops pulled them over his beloved green machine wound up on a flatbed.
And I'm taking this hip hop guy off block list now. he seems alright.
Old 09-21-2012, 11:54 AM   #63
trizzuth
HAHAAAA, i feel so privileged.
Calling all E46Fanatics to the rescue! OK, Came home early from quick physical at MD, tried DMax hose method, but instead of nice insulated garden hoses, I used two of those krinkly hoses that came with my pool filter, what a joke all they did was amplify the sound of air and road!
So came back home, jacked car up, got underneath with camera, and this time, started her up and left the wheels on and went up to 4th gear. Check this out, My bet is now 100% that it's the right rear half shaft and/or bearing. Please review all vids and provide your opinion, it is greatly appreciated!!!
http://s905.photobucket.com/albums/a...pse284ddcf.mp4
http://s905.photobucket.com/albums/a...psf69ea7e9.mp4
http://s905.photobucket.com/albums/a...psc9f282d4.mp4
Old 09-21-2012, 11:56 AM   #64
trizzuth
if it is the halfshaft and/or bearing, how immediately should I fix this? I plan on doing this ASAP, but need to obvs wait for parts to come in which usually takes a week or so depending on where I get them from.
Old 09-21-2012, 03:07 PM   #65
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I once had a mechanic think half-shaft...but it was just bearing. That's my experience...not really data, but datum!
Since I know my half shafts are original, I'll just guess the odds favor bearings.
Yea, the pool hose wouldn't work too well. I actually use flexible electrician's conduit 1" d. It's very stable and insulates against nearby sound.
I'll look in on your vid, but odds are, I won' t think differently than 'the odds.'
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-22-2012, 09:07 AM   #66
trizzuth
to get some of you to watch these vids and help me diagnose this
Old 09-22-2012, 09:13 AM   #67
dmax
dmax's Avatar
Okay, saw the first vid...and I'm thinking that it sounds light and tiney, and you've really only complained about sound, not so much handling (but I'm not reading everything again!)...have you tried pulling your dustshield back at tad all the way around and back?
When replacing wheel, make sure the mating surfaces are really clean...I think you know that...but forget who knows what around here!
Mangofy your E46!
Old 09-22-2012, 09:38 AM   #68
trizzuth
Yeah, wheel is flush to face of rotor, have not yet pulled back boot to inspect, but have the pliers for those specific clamps coming in soon and will do this. Just nervous as I drive this daily and often times do 100 mile round trips to another building for work, not to mention take my kids around on the highway. Also worried this vibration will f up my diff and make things worse.
Old 09-22-2012, 09:43 AM   #69
dmax
dmax's Avatar
I meant the dust shield for the brake rotor...the large thin disk of metal that's within a 1/16" of the rotor. It seems to often get bent...pulled into the rotor.
You can pull it back firmly around its outer edges.
When wheels go on and off, I think it often gets caught and pulled out a tad.
It's springy stuff...so pull firmly(ish) all the way around.
Mangofy your E46!
Old 09-22-2012, 11:31 AM   #70
dknightd
My Ride: 2002 330 cic
Can't view vid without logging in. I think it might be time to take mango's advice. Replace everything. Do it often. Use only BMW parts.
Before you do that check your backing plate/dust shield for rust - if you live in the rust belt - maybe it is just rubbing
dknightd is online now   Reply With Quote
Old 09-22-2012, 11:38 AM   #71
Skchamaa11
My Ride: 2001 BMW 330ci
Sound like a wheel bearing that's going to get louder and louder
Whether you win by a inch or a mile winning is winning
Skchamaa11 is offline   Reply With Quote
Old 09-22-2012, 05:44 PM   #72
trizzuth
already thought about this because of using the "board" method when installing springs awhile back and the board was resting on the brake dust shield and it got bent. Nope, they are all straight, it's the half shaft, watch all videos again closely and listen, and you shouldn't have to log in to see any of them...
Old 09-25-2012, 11:30 AM   #73
trizzuth
Update: Ended up ordering an "FEQ" brand half shaft from Carquest, good thing it is returnable, this is a "just in case" part. Found a used half shaft from a 2002 330i with 93K on the ODO when it was pulled on ebay for $69 shipped. Bought this and it is coming in by friday. So when that gets here, I will replace the bad half shaft immediately. If the noise does not go away after this, I'm burning this b itch. If there is some issue with the new (used) half shaft, then I put chinese crap into my car and it will cry, but at least it will hold for awhile until I can source a better and newer used part. Can't beat the price!
Old 09-25-2012, 02:41 PM   #74
Alex323Ci
My Ride: M3 & 323Ci (sold)
sorry hard one to pin point exactly.
curious as to when's the last time you checked the diff fluid level? hard to tell in the vid but it sounds similar to a diff gear whine. also understand the wheels are at an angle hanging down when you did that test.
Old 09-25-2012, 03:31 PM   #75
trizzuth
Yeah, I know it's a major PITA.
Checked diff fluid level? never changed diff fluid? never
Need to research how to check diff fluid level, unless it's so easy you can just tell me how. While I am under there I might as well check if I can.
Old 09-25-2012, 03:41 PM   #76
trizzuth
Great thread, will def be doing this soon!
http://forum.e46fanatics.com/showthr...ff+fluid+level
Old 09-25-2012, 04:08 PM   #77
Alex323Ci
well it's a closed unit so it in theory should not lose any fluid unless there is a leak. but at your mileage i would check for sure since it's easy to do and eliminates a "possible" cause.
here's one from years ago.
http://www.bokchoys.com/differential/diff_fluid.htm
but don't let me send you off on another hunt. just something to consider
Old 09-25-2012, 04:26 PM   #78
jdstrickland
My Ride: '94 325iC & '00 323i
Late to the game here, I ignored this for as long as I could.
You have a bearing problem. Period. You could have a tire problem, but you seem to have eliminated that by replacing the tires.
Bearings that turn at the same speed as the tires,
The transmission output shaft, the center support, the differential pinion gear bearing, the bearings of the axle half shafts where they fit into the differential, and where they go into the wheel hubs. By my count, I arrive at 7 different bearings.
Most cars will have the wheel bearings go out first, mostly (I suppose) because they actually carry the weight of the car. All of the other bearings merely support a rotating shaft in a stationary housing, so there is virtually no weight placed on them. I would start my search for the noise you describe with the wheel bearings at the outer ends of the axle half-shafts.
Old 09-26-2012, 01:29 AM   #79
otters86
My Ride: 318i
Awesome thread! I have the same problem with my car, so this is REALLY useful! Im not exactly an expert on these things but what problems can you occur if you dont get it fixed straight away?
otters86 is offline   Reply With Quote
Old 09-26-2012, 07:56 AM   #80
trizzuth
I can only assume that with the amount of weight spinning on the half shaft, if it's out of balance for some reason as mine appears to be, eventually the bearing will get destroyed and potentially the diff as well. At least that's what scares me now. I suppose it could also blow apart on the highway, imagine the half shaft, still connected to one end, whether it be the diff or bearing and spinning around like that under your car? YIKES> Gas tank is right there too.
I'm honestly pushing it waiting for my used part to come in, but from the opinions I have gathered, I cannot put this chinese junk FEQ shaft in or I'll be sorry. may take it out of the box today and take some pics so I can compare it to OEM for everyone to see.
dmax furry chest
