Old 08-06-2012, 04:19 PM   #1
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
BMW 6 disc CD changer Error
Use the link below as a guide to remove the CD changer from the trunk:
http://m3.madrussian.net/diy_alpine.shtml
**Solution** is to spray 'Silicone Lubricant' to the mechanical part only. Do not spray on to the lense.
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 02-23-2013, 02:42 PM   #2
parttimesb
My Ride: 51 M3
I keep getting a intermittent ' no disc' error on my 6 disc changer. Is this the same issue as above.
Looking for a fix.
parttimesb is offline   Reply With Quote
Old 02-26-2013, 01:00 PM   #3
streamline
My Ride: 325i saloon
I had the same issue with my CD-changer, your lens is not clean enough to read the cd,
When you got it out of the car you can open the housing, inside you will find the actual changer and reader. Pop out the little shockabsorbers and release the springs.
Take the whole thing out carefully (watch the short wires) and turn the little sprockets at the bottom until you can see the lens trough the opening on the top.
Use some pure alcohol on a piece of cotton and wipe it carefully, repeat that a couple of times and put it back together and it will work as new.
But it's not an easy job..
streamline is offline   Reply With Quote
