Old 08-06-2012, 06:43 PM   #1
Nate323Ci
My Ride: 323 Ci
Car jerked left and DCS light came on.
I was coming to a red light and was pushing the brake pedal when the car jerked left for a split second and my DSC light came on. My OBD scanner doesn't pick up anything, but it's just a generic OBD scanner so I didnt expect i to.
If I turn the car off and back on, the DSC light blinks rapidly.
Any ideas?
Nate323Ci is offline   Reply With Quote
Old 08-10-2012, 02:24 PM   #2
S-Dizzey
My Ride: Imola e46 M3
Same here, the dsc button and my tire sensor came on, i was on the fwy and the car jerked and pushed me to the second lane, luckily no one was next to me, but I still dont know what it is, the tires are all good and now i have to drive with the traction controll off, ive seen some people say it is the speed sensor that is bad... But does anyone have this problem fixed ???
S-Dizzey is offline   Reply With Quote
Old 08-10-2012, 03:01 PM   #3
scrace
My Ride: 03.5 M3
Do you think a control arm failed? Have you checked the bushings?
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-10-2012, 07:16 PM   #4
scottjoh
My Ride: '99 323i & '02 540i
Not a control arm problem. To properly diagnose you need the DSC codes read to find out which sensor gave the, obviously, erroneous reading. It is probably yaw rate plausible reading. Generic code readers do not read anything except engine codes.
scottjoh is offline   Reply With Quote
Old 08-10-2012, 09:22 PM   #5
azshorty
My Ride: Hellrot 323CI
traction control kicked in maybe?
azshorty is offline   Reply With Quote
Old 08-10-2012, 10:42 PM   #6
BeaminSway
My Ride: 323i
The jerk made the traction control activate . Same if you tail whip or try to drift .
BeaminSway is offline   Reply With Quote
Old 08-10-2012, 10:44 PM   #7
BeaminSway
My Ride: 323i
Just makes sure that you're tires don't slip .
Old 08-11-2012, 12:46 AM   #8
scottjoh
Typically tracking control kicks in because a sensor is glitchy and then it realizes something was wrong and throws up the fault light. Codes must be read out to determine the cause.
