Old 08-06-2012, 06:56 PM   #1
330Cole
My Ride: 01' 330Ci
oil disappearing
changed my oil at 137k and im at 139k now. light came on when i shut the car off and oil was down to the lowest notch on the dipstick. i dumpped in a quart but why did this happen? do i have a leak? am i burning oil? or is this normal?
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 08-07-2012, 12:13 AM   #2
Steven747
My Ride: 05 330ci
ccv
Old 10-01-2012, 02:04 AM   #3
Beamer Creamer
My Ride: 2005 bmw m3
I duno. Do you have an external leak?Do compression test and if differential isnt within spec. Wet test to see if rings or valves. All engines have some blowby but thats excessive burning or leaking
Beamer Creamer is offline   Reply With Quote
Old 10-01-2012, 03:45 AM   #4
Steven747
My Ride: 05 330ci
i see you bumped like 15 threads here with comments.
to op like i said check your ccv also check your valve cover gasket as well as ofhg and then report back
Old 10-01-2012, 03:53 AM   #5
Beamer Creamer
What. Should i quit or what. I dont know alot of abbrevs but im also bored sitting in semi for 12 hrs doing nuthin. My wrists are too sore for anymore porn. What do u recommend? Is my info shit or what?
Old 10-01-2012, 12:29 PM   #6
Steven747
My Ride: 05 330ci
sounds like you dont know common leak points for the m54
Old 10-01-2012, 09:51 PM   #7
Beamer Creamer
Ok. Leak points dont matter. Just were ever the fluid is leaking from. Its kinda sounds like you might have a little leak of your own so i'll leave
Old 10-02-2012, 01:50 AM   #8
Steven747
My Ride: 05 330ci
usually if you look at the common spots its easier to locate a leak than looking in every random spot
Old 10-02-2012, 03:05 AM   #9
Beamer Creamer
Ya i guess thats true. Our engines are quite a few feet long so might be kinda hard to spot a 1 liter oil leak
Old 10-02-2012, 03:31 AM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Ccv
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-02-2012, 03:36 AM   #11
Beamer Creamer
Ya i know im slow but Ccv means what?
Old 10-02-2012, 11:49 AM   #12
Steven747
My Ride: 05 330ci
crank case ventilation assembly
Old 10-02-2012, 02:59 PM   #13
j_block
My Ride: 2003 325i
Google is your friend
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 10-02-2012, 05:04 PM   #14
VG1134
Old City Bimmer
My Ride: Classifieds
Man your car is thirsty. That's a lot of oil. CCv, oil cap, filter housing o- ring, engines leaks,etc,. So to answer your main question- yeah that's not normal amount.
VG1134 is offline   Reply With Quote
Old 10-02-2012, 05:10 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
Oil separator
$120 for four hoses and the separator +3-5 hours of cutting up your hands.
