Old 08-07-2012, 11:11 AM   #1
dude dog
My Ride: BMW
Ticking noise from coils?
I changed my vcg yesterday and before I put everything back on like the plastic covers I was checking to make sure that the oil leak was fixed. I started the car and took it for a drive and when I got back I did a visual. Everything looked fine but I noticed a ticking sound coming from the coils. I thought it was just the front one but the sound was coming from each spark plug. I took a hose and listened closer and each 1 was making the noise. Car runs fine except for the ticking. I waited till dark to check if I could see any type of sparking that was coming off but nothing. Any suggestions?
dude dog is offline   Reply With Quote
Old 08-07-2012, 11:58 AM   #2
RA733
My Ride: 323i
Sounds like u just found out wht a coil ossolation sounds like, if its running you should be fine.
Sent from my myTouch_4G_Slide using Bimmer App
RA733 is offline   Reply With Quote
Old 08-07-2012, 06:34 PM   #3
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
you're supposed to let the RTV sealant cure for an hour (I've also heard 12)
Schlag96 is offline   Reply With Quote
Old 08-07-2012, 07:14 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Also check the torque on your spark plugs and make sure the coils are fully seated.
Old 08-07-2012, 08:32 PM   #5
///MPR77
My Ride: 02 ///M3 Tri-Ped
+1
Sounds like a plug has loosened and backed out.
Old 08-11-2012, 04:38 AM   #6
RA733
My Ride: 323i
So did u fix it, what happened????
