Old 08-07-2012, 02:03 PM   #1
benzedid
My Ride: 2001 BMW E46 318i
Erratic RPM without starting engine???
My ride: BMW E46 318i
Engine: M43B19
In short:
1. I switch on the ignition (Engine has not yet been started).
2. RPM start bouncing completely erratic. Erratic movement ranges from 0RPM to 6000RPM. It stops after a few seconds. ASC light turns on.
3. I try starting the engine. It cranks but won't turn on.
4. I let the car rest for a few minutes. Then I try turning the engine on again. It starts normally.
5. Try to pull out fault code: It says "Camshaft Position Sensor".
The problem repeat itself every 2 or 3 days.
Question for you dear fanatics is: Have you ever experienced these symptoms with a defective camshaft position sensor? Will replacing the camshaft position sensor solve the problem? It should be replaced for sure but I need to know whether I should replace other parts that are not showing up on the OBD scanner.
Thanks for your help.
benzedid is offline   Reply With Quote
Old 08-08-2012, 11:43 PM   #2
paraklas
My Ride: ESS TS2 320ci
Replace the camshaft position sensor. Clear codes, then see if problem appears. Wont do any good at all randomly replacing parts. Your issues may be unrelated as well. Also do a cluster reset it may fix the problem
Old 08-09-2012, 01:03 AM   #3
benzedid
Did the cluster test. Everything work fine. Unrelated for sure. I don't see how a camshaft position sensor can be related to the RPM needle. As far as I know, the RPM sensor is usually located on the crankshaft.
Old 10-01-2012, 12:55 AM   #4
Beamer Creamer
My Ride: 2005 bmw m3
True but lots of electronics are linked together through f... In computers.
Beamer Creamer is offline   Reply With Quote
Old 10-03-2012, 10:07 AM   #5
Quenotte
My Ride: E46
Maybe you can test your battery. Low battery charge can cause such funny things
Quenotte is offline   Reply With Quote
Old 02-05-2013, 07:58 AM   #6
benzedid
Happened to solve the problem. An OBD scan revealed the crankshaft position sensor was defective too. Replaced both of them. Now it works fine.
cps, dme, m43b19
