Old 08-08-2012, 06:02 AM   #1
POLECAT
My Ride: 2001 330ci M-T
Burning fail cylinder 1,2,6
hi guys. i have this problem recently. when i start the car, it works loud during cold starting. i have searched in the internet. everyone say the spark plug and coil pack cause this problem. but i have changed all spark plugs and coil pack last year. what should i check else ? thanks
BMW For Life
POLECAT is offline   Reply With Quote
Old 08-08-2012, 06:19 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Doubt you would have 3 bad coils at the same time, also high Voltage ignition problems usually happen under heavy load, not start up.
Suggest you check the first link below in my signature.
I would consider replacing the DISA O-ring and check over all other rubber and plastic hoses, especially SAP vacuum hoses if your car has the SAP system.
Old 08-08-2012, 06:27 AM   #3
POLECAT
thanks friend im reading now. i hope so i can solve this problem its make me annoying really
BMW For Life
Old 08-13-2012, 09:10 AM   #4
POLECAT
so i have checked my hoses. but it seems no problem. i have diagnosed again my car today. diagonose gave that faults. i had 3 cylinders fail. now i have 4
BMW For Life
Old 08-17-2012, 10:59 AM   #5
POLECAT
i have removed intake manifold,spark plugs,ignition coils, etc, and install my headers. but i have still problem. i will make a video tomorrow or today, then you can understand better. my ses light not on.
BMW For Life
Old 08-17-2012, 12:57 PM   #6
POLECAT
i have diagnosed yo my car now. my car have in 6 cylindes misfire. my car had 1-2 cylinders misfires last week. in 1-2-3-6 cylinders misfires 3 days ago. now all cylinders misfires. im going to set out 2 days later. i must to solve this problem until tomorrow. urgently!!!!
BMW For Life
Old 08-17-2012, 01:00 PM   #7
xavi330i
My Ride: 2004 330i smg
The last time I had 6 cylinders misfire was when my CCV caused excessive oil to be sucked into my intake. Evidence of this can be seen on the plugs for oil fouling.
xavi330i is offline   Reply With Quote
