Old 08-08-2012, 11:22 AM   #1
GotVANOS?
My Ride: 2003 325xi Touring
Solid lifter conversion. what's required?
I'm still in the idea phase but I was wondering what is required to do a solid lifter conversion on an M54. I've done quite a bit of searching and havent really found much. Schrick makes a conversion kit but wouldnt you need cams for solid lifters? Can you even get solid lifter cams for an M54?
http://www.turnermotorsport.com/p-16...d-lifters.aspx
Shes not your average grocery getter. This 2.5L of fury doesnt mess around.
E21<E30>E36>E46>E90>F30
5TFUUU, If one more person tells me to sell my car and buy an ///M Im going to light their family on fire and make them watch.
*****BUY MY 330XI AUTO TRANS AND PARTS. CHEAP!!!******
GotVANOS? is offline   Reply With Quote
Old 08-08-2012, 11:23 AM   #2
Grande D
My Ride: E36 M3
Why? That's the first question. It'll make the motor raspy, make the car higher maintenance, etc. Is your motor built?
It will change your life!
Old 08-08-2012, 11:34 AM   #3
GotVANOS?
Why? Because the car will be at high rpms regularly, faster reving, and rasp. I love rasp. I guess I need to look into the pros and cons more. and No, the motor in my car now has 250,000 miles on it and before I go to college next year it's getting a new engine. Like I said, Im still in the idea phase. Right now Im thinking ZHP cammed M54B30 with solid lifters.
Old 08-08-2012, 11:38 AM   #4
Grande D
My Ride: E36 M3
Well huh. At high RPMS M54B30s have vibration issues. That'd be the first thing you should look into. ZHP cams don't make power high enough to require solid lifters.
Old 08-08-2012, 11:41 AM   #5
My Ride: Lexus
+1. oil pump, oil pump nut, new OE damper or upgraded damper. Though I'm not sure if the jury is out on the long-term nature of the ATI damper. might as well spend money where it counts.
Old 08-08-2012, 02:44 PM   #6
Grande D
My Ride: E36 M3
Wait let me try that again. ZHP BEST CAMS EVAR OF ALL TIME MAKE POWER TO 8K NO PROBLEMS.
Old 08-09-2012, 09:37 AM   #7
Zabusa
My Ride: 2004 BMW 325
Which damper are you referring to Mango? This upgrades are interesting..
Zabusa is offline   Reply With Quote
Old 08-09-2012, 09:44 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Not worth it.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-09-2012, 12:15 PM   #9
swaggerwagon
My Ride: 2005 330i
unless you have a fi cams and are running high HP then solid lifters wont make any difference. on cold start it will make a tapping sound due to valve train growth.
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 08-09-2012, 12:51 PM   #10
Grande D
My Ride: E36 M3
ATI, SFI was on the table too but I think that one's dead in the water.
Old 04-02-2014, 06:41 AM   #11
kevindsheaka
My Ride: 330i zhp manual
Has anyone on the forum done a m54 solid lifter conversion yet? I am also curious if this conversion will work with the zhp cams, I was thinking redline approx 7400 track auto cross application. Obviously drilled and cotter pinned oil pump shaft/ nut. With a rear subframe complete with m3 diff swap from an m3. The extra revs should work well with the stock m3 diff ratio.
kevindsheaka is offline   Reply With Quote
Old 04-02-2014, 06:49 AM   #12
Brevik
My Ride: Tiag M3
IMHO-Not worth the effort for this application, move on to something else.
Brevik is offline   Reply With Quote
Old 04-02-2014, 08:34 AM   #13
Knight
My Ride: '05 330Ci | '01 325i
Why would you need a higher redline for Auto-X? Tighter track would benefit from more oomph in the midrange of the power band.
Knight is offline   Reply With Quote
Old 04-02-2014, 09:55 AM   #14
JasonLI25t
My Ride: 2000 323ci
no need to get cute, for similar money you could put a well-running stock engine in there and throw on a supercharger and make way more power in every way than if you decided to go your route. Plus they are bolt on and reversible, and like mentioned earlier, if auto-x is your goal, midrange is what you want and the midrange punch of a supercharged M54 is superb.
JasonLI25t is offline   Reply With Quote
Old 04-02-2014, 10:18 AM   #15
WDE46
My Ride: '13 128i, '04 330Ci
There is absolutely no reason to do this.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-02-2014, 10:27 AM   #16
NOVAbimmer
My Ride: E60M
E46F, solving problems that don't exist since Dec 1969
NOVAbimmer is offline   Reply With Quote
Old 05-05-2014, 01:48 AM   #17
Flop
My Ride: '04 330Ci 6MT
I have never seen a forum full of more haters than E46fanatics... Just about any thread that talks more "aggressive" ideas is shunned upon on this site. Not a single response to the OP's original question.
VAC makes a kit http://store.vacmotorsports.com/vac-...-24-p1034.aspx
Based on what it says there, it requires specific solid lifter camshafts. I would call them to make sure, though, as I can't seem to figure out why (mechanically) a different cam would be needed... Unless they require a smaller/larger base circle.
Flop is offline   Reply With Quote
Old 05-05-2014, 08:55 AM   #18
willsbma
My Ride: 99 323i
I would worry more about the oil pump shaft shearing off, even with the nut welded on. I have 330 cams with solid lifters and bmw motorsports oil pump, 12k springs and ti retainers for higher revs. I can turn 9500 and it has on the track, but cams are going to play a huge part here. Also, it is extremely loud at idle and all the way up the range. But it has a distinct sound, it's fun to not have to worry about a money shift anymore lol.
ETA: the vac kit most likely calls for specific cams to make advertised power.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 05-05-2014, 09:21 AM   #19
NOVAbimmer
My Ride: E60M
here's the issue: with the VAC kit, you're paying $3700 for parts that will give you 20ish hp, above 5000 RPM. Which is great if you're actively tracking a solidly-built NA car, but is nearly useless on the street unless you're looking for an old-school lopey idle and an uncomfortable ride.
Old 05-05-2014, 09:47 AM   #20
willsbma
My Ride: 99 323i
With the right cams you will make way more than 20hp. But it will require other things. Basically the only way to make real power with solid lifters is huge cams which will require you lock down the vanos and run a standalone. Your idle will be somewhere around 1800rpm and you'll have to turn 83-8500 rpm to make that power. Now you're talking forged motor to handle higher revs. Doing that I would expect about 70/80 hp more, by now you're $10k deep and only 280hp, sure you can out rev an M, but not outrun it. Solid lifters sound cool and you can definitely rev the balls out of it, but it's only practical for track only applications.
lifters, m54, valve, valve adjustment kit
