#1 |
coolant leak?
i am suspecting a leak because dipstick is reading low but no low coolant light. also when i put some more coolant in the next few days it will go back to reading low (dipstick) but i do not see any coolant on the ground or leakage anywhere around the car. is this a normal thing to lose a bit of coolant during the summer? also the amount of coolant that i add is a very small amount about a 3/4 of a cup.
Sent from my SGH-T989 using Bimmer App |
#2 |
Maybe your coolant tank cracked. That happened to me, and the thermostat was toast. But then again, my driveway was flooded with coolant :O
#3 |
yea i see no sign of coolant on the floor, Idk maybe i'm its fine but i just want to be safe.
#4 |
My Ride: '06 330CiC, '03 M5
Check the sensor in the lower radiator hose, the O-rings leak all the time.
If there is any moisture under the switch onto of the belly pan, your O-ring needs to be replaced. See my signature below for the O-ring part number.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
