Old 08-09-2012, 04:14 PM   #1
ckberry
My Ride: 2002 330i Sedan
Overheated: What Should I Replace?
My wife just drove our '02 330i while it was overheated. She's not sure how long she drove it that way, maybe a couple miles (which I know is more than enough). When I tried to start it after she got home (maybe that wasn't smart, but I wanted to see what it did) the temp needle immediately pegged to the right, the engine clicked loudly, ran rough, and then stalled. I was certain it was DOA.
However, I went out the next day and it started fine with the temp needle right in the middle. I topped the water off and bled the coolant then took it for a short drive and it had plenty of power and drove smoothly for a 30 minute drive. Water is steaming out of a crack in the side of the radiator, but I know that's an easy fix.
I had known there was a slow coolant leak before, but I couldn't tell where it was coming from so I recently replaced the Thermostat, Water Pump (with an EMP Stewart), and both hoses. That didn't solve the leak, but it was very slow so I procrastinated on replacing the radiator and expansion tank (kicking myself now.)
Questions: When I replace the radiator and expansion tank, should I repair the following?:
1. Since it over heated after those repairs, do I still need replace the thermostat even though it's almost new? (I know with older engines this was always advised, but the thermostat seems to be operating normally.)
2. Should I tackle the fan clutch while I'm at it?
3. Do I need to change the oil or should the fully synthetic stuff be okay with the brief overheat? (I changed it less than 1k miles ago.)
4. Would anything else be damaged? Please don't say the new $200 water pump.
5. Is there still a good chance that the top end is fried and I would just be wasting my money on all of the above repairs?
Thanks gang. Chris
ckberry is offline   Reply With Quote
Old 08-09-2012, 04:29 PM   #2
eclipsor
My Ride: stahlblau
Send a message via AIM to eclipsor
be sure to search or check the stickied threads:
http://forum.e46fanatics.com/showthread.php?t=914109
Jet Black 1994 325is -> Steelblue 2003 325i
eclipsor is offline   Reply With Quote
Old 08-09-2012, 04:35 PM   #3
ckberry
Thanks. I wish I had read this thread a few months ago. Now, unfortunately, I'm looking for what to do when these things have already happened.
Old 08-09-2012, 04:54 PM   #4
peytonracer4
My Ride: '00 328i
You'll know if your head gasket blew and head warped pretty soon after the overheat, if not immediately.
If your engine is ok then just solve the leak (radiator)
Old 08-09-2012, 05:00 PM   #5
BimmersGarage
My Ride: E46 330i
Send a message via Skype™ to BimmersGarage
Your thermo, WP, & rad. hoses should be ok.
Replace radiator and expansion tank (get a NEW cap with it), asap.
While you're there do fan clutch and fan blades, plus all pulleys and belts. Probably a good idea to get a new auxiliary temp. sensor (for the lower rad. hose, if you haven't already). Fill with BMW coolant and re-bleed.
Report back.
BimmersGarage is offline   Reply With Quote
Old 08-09-2012, 05:08 PM   #6
Mau330i
My Ride: '02 330i
I was in a similar situation a few months ago...
http://forum.e46fanatics.com/showthr...202&highlight=
My car ran ok for the first days after replacing expansion tank and then every thing started.... so before changing anything I would suggest to drive the car a few days and see how it behaves.
Good Luck
Mau330i is offline   Reply With Quote
Old 08-09-2012, 06:39 PM   #7
danwilz
My Ride: E46 M3 Vert 2012 X5
The Engine.....
danwilz is offline   Reply With Quote
Old 08-09-2012, 08:02 PM   #8
trive2
My Ride: 1989 BMW 535i
Yup, I can't see the engine still being serviceable long term.
trive2 is offline   Reply With Quote
Old 08-09-2012, 08:10 PM   #9
MercForHire
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
Sell car now!!
Preferably to an undeserving high schooler.
Oops! My Water Pump Broke Again .................... Coolant in a Bottle
Old 08-09-2012, 08:12 PM   #10
mkodama
mkodama's Avatar
Do a leak down test. If pressure holds, and your coolant level doesn't rise while you're doing the test, you're probably fine.
If it does leak, time for a new engine.
Old 08-09-2012, 08:16 PM   #11
MercForHire
Sh1tty Advisor
Replace the wife
Old 08-09-2012, 08:31 PM   #12
BimmersGarage
My Ride: E46 330i
That's a bit harsh..
Old 08-09-2012, 08:33 PM   #13
scrace
My Ride: 03.5 M3
You're looking at $400-500 in parts and another 80-110k miles of reliability of the cooling system.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-09-2012, 08:48 PM   #14
mkodama
mkodama's Avatar
That's to replace cooling system parts. This guy needs to find out if his engine is toast, or spending $400-500 on cooling parts for a toasted engine probably wouldn't do him much good.
Old 08-10-2012, 10:01 AM   #15
Platinum Plus Quality
My Ride: M54B30
Some people think I'm harsh or trolling for telling some new members about the cooling system when they post "what color" or "how wide" threads...
Now you know why.
(As if the other 8,000 threads where people say "I wish I would have seen this information earlier." weren't telling enough)
The fight continues. Good luck, OP.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 08-10-2012, 10:05 AM   #16
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
It's a good fight nonetheless, Mango.
Anyway, so what color and how wide? I'm curious to know your thinking on that!
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 08-10-2012, 10:31 AM   #17
DHK
My Ride: 2002 BMW 325Ci
I would just drive it a little, short trips, few times a day next few days. See if any lights come on or anything else bad happens. If the light comes on then you'll at least have codes to give you a guide to what else might be wrong. If nothing pops replace the cooling system and hope everything else is fine.
DHK is offline   Reply With Quote
Old 08-10-2012, 10:33 AM   #18
e46Ron
My Ride: 2002 330ci
Check your anti-freeze
Sent from my LG-E739 using Bimmer App
e46Ron is offline   Reply With Quote
Old 08-10-2012, 11:50 AM   #19
cak323i
My Ride: ///M3 & 330i ZHP
+1
Sound advice
2004 TiAg ///M3
2003 Imola Red 330i ZHP
1999 Electric Red 323i - SOLD
cak323i is offline   Reply With Quote
Old 08-10-2012, 12:10 PM   #20
My Ride: M54B30
Black. About 8.5 inches.
(What! talking about plasti-dipped stock rear M68 wheels!)
coolant, overheat, overheated, radiator, thermostat
