Old 10-10-2012, 07:36 AM   #21
ault786
My Ride: 330ci
What are the reasons you picked Dinan over Ess trans. tuning?
Was your trans slipping?
I'm considering doing the same thing.
Can you give us an update please.
ault786 is offline   Reply With Quote
Old 10-12-2012, 08:45 PM   #22
TrippinBimmer
My Ride: Just Fast!
Originally Posted by KPTuned View Post
Any internal adjustments? I have heard about adjusting and shimming a pressure valve for harder shifts but I cant find any definitive details.
Yes, there is 2 Internal Adjustment you can do. I will be go into more details below...
Originally Posted by ault786 View Post
What are the reasons you picked Dinan over Ess trans. tuning? No, Trans Tune for the GM Transmission.
Was your trans slipping? No, but the rubber band effect causing my trans to heat up and wear more parts then should be. Will cause the Trans to fail at a future date.
It's well worth the upgrade. I will be doing a few more things to make it more effective but until then. I won't release it to the public.
Here is how the EGS unit looks like opened up
Here is the settings that can be adj on the unit
When going up in pressure on the TQ it is only for 4th and 5th gear(mostly). You do feel it shift alittle crisper 2-3 but not that noticeable.
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-28-2012, 12:44 PM   #23
ault786
My Ride: 330ci
Did you get to finish your project?
Old 11-28-2012, 01:32 PM   #24
TrippinBimmer
My Ride: Just Fast!
wont be finished until next year....
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-29-2012, 04:01 AM   #25
SUHLeen
My Ride: 2005 Saleen Mustang
This may be an ignorant question but what is the TCU?
And can the eco-tuning mod be done to a ZF tranny car?
Sent from my Galaxy Nexus using Bimmer App
- Phil
11 335is - TT 7 spd DCT daily :)
05 Saleen Mustang - forged, stroked, blown,... and on some juice
01 BMW 330ci - Totaled by some bish!
Financial Help
SUHLeen is offline   Reply With Quote
Old 11-29-2012, 07:41 AM   #26
TrippinBimmer
My Ride: Just Fast!
Transmission control unit or EGS.
Yes
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-06-2013, 02:59 PM   #27
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Whats with Torque Converter Clutch from first gear on ? Dinan-Software tested?
Hageee is offline   Reply With Quote
Old 01-06-2013, 04:05 PM   #28
TrippinBimmer
My Ride: Just Fast!
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-18-2013, 01:41 AM   #29
btec116
My Ride: 330i ZHP
I'm liking this thread! Just bought a ZHP (GM) auto - would prefer a manual, but when you're on a budget beggars can't be choosers.
Nevertheless, I'm probably going to like it while stuck in Bay traffic...
So could you tell us more about your stage 3 plan?
3. IPT 5L40-E Modified Valve Body (High Priority)
Reduce or Eliminate the Shift Overlap
How's this work exactly? Is this decreasing the time taken transferring drive from one gearset to the next? I'd like the idea of this as I find the time taken between shifts to be a little excessive, even when shifting myself.
btec116 is offline   Reply With Quote
Old 01-18-2013, 02:43 AM   #30
daniel_f.
My Ride: 330iC
youŽd better get yourself a ZF6HP21. you wonŽt be able to get much shorter shift time, it depends on the oilflow.
Old 02-07-2013, 12:49 AM   #31
TrippinBimmer
My Ride: Just Fast!
That is correct but with the modded VB it will cure this Issue. My car is about to be on JackStand for another 1-2 months for a Revamp and Redesign on some of my parts...(redoing the 3" exhaust to quiet it down with electronic cutouts)
-Trip
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
