Old 08-10-2012, 06:13 AM   #1
spikester550
My Ride: 330ci, 86.5 hardbody
Send a message via AIM to spikester550
Thumbs down official limping me crazy
Hey guys so my 330 is driving me crazy. It goes into limp mode when I'm usually going mph+ and throws a p1620 and a p1500 codes but not all the time people where saying maf or map? Idk is just driving me crazy. Anyone know or can point me in the right direction?
MODS
ESS TX2, 3.38 Diff, K&N CAI, 19" LM's, UUC TSE3,
30 LED AE, OEM MT2 Front & Rear,
CF CSL Trunk, Black Kidney Grills, Smoked Corners,
Painted Reflectors, M3 Steering Wheel,
ZHP Shift Knob, Clutch Stop, Shark Injector,
15mm Spacers, 3k DDM HID Fogs, OEM M3 Hood,
Coilovers, UUC Sways, and many more..
spikester550 is offline   Reply With Quote
Old 08-10-2012, 10:18 AM   #2
spikester550
Ttt
MODS
Old 08-10-2012, 07:06 PM   #3
spikester550
Bump
MODS
Old 12-12-2013, 09:38 PM   #4
spikester550
plz anyone still driving me nuts somewhat i think it may have to do with the battery? idk i have replaced the idle air control valve
MODS
Old 12-13-2013, 02:29 AM   #5
2003silver330i
My Ride: 03 BMW 330i
The code P1620 has to do with a bad thermostat. Replace it with a genuine OEM thermostat. Concerning the P1500 code I see that you are using a K&N CAI which could be contributing to the P1500 code. If it was my car the first thing I would do is clean the MAF sensor and MAF connector with a cleaner specifically made for the MAF sensor. Next I would clean the connector to the ICV. If none of that stuff clears the code then remove the K&N CAI and put the stock air filter box back in and clean the MAF sensor one last time.
The 2 happiest days of a BMW owner's life is the day they buy it and the day they sell it.
BMW (Broke My Wallet)
2003silver330i is offline   Reply With Quote
Old 12-13-2013, 02:37 AM   #6
FooFighter94
My Ride: 2001 325Cic
This^
Often times, CAIs which need to be oiled regularly cause MAF problems. I have heard of the oil gunking up the MAF and even destroying it. Never used one so can't say for sure.
WVU Mountaineer
-2001 325Ci Convertible Slushie
-Orient Blue Metallic
-Koni Yellows, Otherwise hella stock
FooFighter94 is offline   Reply With Quote
Old 12-13-2013, 02:45 AM   #7
2003silver330i
If none of those suggestions work then you most likely have a wiring issue.
Old 12-13-2013, 08:13 PM   #8
spikester550
well i am using a light weight battery the maf is as clean as a wistle and thermo was changed about 4 months ago and i have had this issue longer. some people were saying it might be the batt?
MODS
Old 12-13-2013, 09:08 PM   #9
lszlszx
My Ride: 1.8T, XC70
The battery can cause limp mode if voltage is too low.
Did you use a generic code reader to scan?
The one reason why I would ever take my car to the dealer is
for diagnosis. It doesn't cost too much and it can save you head ache.
You posted this over a year ago. How often does the car go into limp mode?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 12-14-2013, 01:18 AM   #10
spikester550
yeah just a generic code reader. i have been having it off ona dn on but just recently it got worse but it always happens if i keep the throttle steady on a certain speed so its annoying as hell on the freeway lol
MODS
Old 12-14-2013, 02:15 AM   #11
2003silver330i
Bear with me I'm just throwing some ideas out there. Have you tried clearing the codes and unplugging the MAF to see if the car still goes into limp mode?
Old 12-19-2013, 10:06 AM   #12
jfoj
My Ride: 330CiC, M5, X5
Might want to check toward the end of this thread - http://forum.e46fanatics.com/showthr...ighlight=p1500
The person had intermittent P1500 and after a long time chasing it, turned out it appeared the 12V MAF supply wiring had a break in it. He also has CAI as well.
I see you have a lot of mods on your car, so not sure if and why the wire broke on that car. I know all about the trunk wiring harness breaking at the hinge location, but the MAF wiring should not have a lot of movement and should not break, but maybe the German wiring was not annealed enough and constant heat and vibration cause fractures in the wiring??
Just something to consider.
Old 01-04-2014, 10:08 PM   #13
spikester550
So I did some research cause I was also getting terrible idle rpms. So I cleaned the mad careful and now Im starting to get maf codes so I'm guessing my maf is takin a dump. When I unplug the maf everything works well no idle or 1500 codes so I'm thinking it the maf and the wires? The battery seems to be tight and in good order. If anyone else has any other suggestions don't hesitate =]
Thx guys
MODS
Old 01-04-2014, 10:54 PM   #14
Weste46
My Ride: 2001 330ci
Re: official limping me crazy
Swap back to your OE air box before anything. I had constant limp mode with P1500, unplugging MAF stopped limp mode. I ended up replacing my ICV and MAF, same codes. Finally swapped back to OE air box, never came back-until a few days ago when I put my CAI back on to check... definitely the intake in my case, and mine is an Apexi Power filter which is a dry filter.
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 01-13-2014, 10:26 PM   #15
spikester550
I can't put the oe air box on cause I'm supercharged. There is no room lol. What is a good way to test the maf or the wires for the maf?
MODS
Old 01-15-2014, 06:36 AM   #16
spikester550
bump if someone has an idea
MODS
Old 01-19-2014, 07:51 AM   #17
spikester550
someone?
MODS
Old 01-24-2014, 04:22 AM   #18
spikester550
MODS
Old 05-06-2014, 12:45 AM   #19
spikester550
This week I'm going to throw money at the maf and the wiring harness since it seems that a wire or two looks exposed. Should I just replace the wires or cut back and shrink wrap? Money is not a problem I want it done right.
MODS
