Old 08-10-2012, 10:06 AM   #1
bmw4me2
My Ride: 2000 328I
code reader gives Error when I try to retrieve codes
I have tried 3 different readers when I plug in under dash, it says error or can't sync. Does anyone know what the problem is?
thanks
bmw4me2 is offline   Reply With Quote
Old 08-10-2012, 01:35 PM   #2
scottjoh
My Ride: '99 323i & '02 540i
Which code readers? Are they BMW code readers or generic OBD-II readers.
scottjoh is offline   Reply With Quote
Old 08-10-2012, 03:37 PM   #3
bmw4me2
My Ride: 2000 328I
Generic code readers. I went to AutoZone, O'Reilly's and my friends reader.
It use to be able to read the codes.
Old 08-10-2012, 06:13 PM   #4
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
is the key on ?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 08-10-2012, 07:08 PM   #5
scottjoh
Generic code readers should work. Like the previous post says ignition must be ON. Not Accessory. ON. There is a DME update required on some cars to get reliable OBD-II operation on certain production run. I think that was only on some M3s.
Old 08-10-2012, 09:48 PM   #6
bmw4me2
My Ride: 2000 328I
Yes, the key is on ignition.
Also, the autozone and o'reilly guys tried to get a reading and it failed.
I tried the reader on our other car and it works.
Old 08-10-2012, 10:55 PM   #7
jfoj
My Ride: 330CiC, M5, X5
Your profile shows you have a 2000 model year car.
Do you have the round connector under the hood?
If so, likely you may need to try to connect under the hood with a round pin adapter and/or you may have a wiring problem with your underdash connector.
Old 08-10-2012, 11:44 PM   #8
bmw4me2
My Ride: 2000 328I
Well I guess fortunately for me the service light went off.
I just received the Peake reader, but I may send it back to Amazon for
a refund if the service engine soon light doesn't come on.
I hit the 200k barrier today.....
Old 08-11-2012, 12:52 AM   #9
TrickTizzle
My Ride: 325i
On MY2000, you need to use the round diagnostic port under the hood.
Old 08-11-2012, 02:52 PM   #10
wasp9166
why? keep it in your glove box, it's the best thing i ever bought for mine
