Old 08-10-2012, 09:09 AM   #1
jgold47
My Ride: 2004 X5 3.0
Sedan Rear Deck Removal-DIY
Hi everyone - I havent been able to find a comprehensive rear deck removal DIY/thread for a sedan (that doesnt have a fold down seat)
As near as I can piece together, you remove the upper and lower seatbacks, remove the headrests, remove the c-pillar and speakers, and then what?
TIA!
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 08-10-2012, 08:40 PM   #2
jgold47
Ok- this was super easy. Here is what I had to do. I have a sedan. I don't have folding seats.
1. tools
T-50 Torx on socket
13mm socket
something to remove your speakers (mine were already aftermarket/different screws)
something long and skinny (not your cack) to pop rivets
flat head
trim popper
needle nose
2.
Remove rear seat by grabbing from under the front and pulling up. It should come out pretty easily.
Remove center headrest. I was able to get mine out just by pulling up.
Stick your hand between where the rear seat hits the doorframe and pull forward. It should pop out, repeat on the other side.
Remove the pop rivets along the front edge of the rear parcel shelf.
Move the other two head rests all the way up
remove the caps covering the baby seat anchors and remove the 13mm nuts
remove your rear deck speakers.
Pop out your c-pillar lights by wedging them out.
pop out your c-pillars by popping them out, just given them a yank.
once you have removed the rivets, stick your trim popper under the front lip and lift up slightly until you can see the headrest posts. You will be able to see the they are held on by c-clips. Use your needle nose pliers to pop the rings off and remove the head rests.
now, everything should be lose except for the seat belts holding everything down.
unscrew the bolts holding the seat belts using the t-50.
now, slide the rear deck forward, it should just slide off - with the seat belts still attached the to deck.
remove those t-50 holding the deck on, and viola, your rear deck should be out.
it took me 25 minutes.
good luck!!
my about me link
Old 11-16-2012, 10:57 AM   #3
markusmarkus
My Ride: 2001 330Ci
Trick!
The trick to removing the rear headrests is to lift the headrest to its highest point and then use the slipjoint pliers to rotate the vertical pins/rods about 45 degrees. The headrests and their associated pins will slide right out.
