Old 08-10-2012, 12:56 PM   #1
2003silver330i
My Ride: 03 BMW 330i
Low coolant light on and a/c blowing warm
First thing this morning the low coolant light came on and the air conditioner is blowing warm air out of the vents. Maybe a dumb question but are these two issues related?
2003silver330i is offline   Reply With Quote
Old 08-10-2012, 12:58 PM   #2
ngillan
My Ride: Is Blacked Out
add coolant?
in for mango's response.....
'02 325ci
Smoked Turn Signals, Tail Lights, and Side Markers, 17"CSL Replicas, Plasti-Dip Grille and Reflectors, Carbon Fiber Wrapped Pillars
Replaced Water Pump, Expansion Tank, Power Steering Pump, Drivebelt Pully, ABS Control Module, Passenger Window Regulator, VCG
Dead
'84 Mercedes 190E
'95 Pontiac Grand Prix GTP
'95 Mitsubishi Eclipse GS
'99 Mitsubishi Eclipse GST
'98 Mitsubishi Eclipse GSX
'99 Cadillac STS
ngillan is offline   Reply With Quote
Old 08-10-2012, 01:02 PM   #3
RPAYNE46
My Ride: '00 328ci
check to make sure your belts are still on
RPAYNE46 is offline   Reply With Quote
Old 08-10-2012, 01:02 PM   #4
2003silver330i
I know it needs some coolant. I usually need to add a little each month.
Old 08-10-2012, 01:15 PM   #5
2003silver330i
Didn't think about that one but will definitely take a look.
Old 08-10-2012, 07:29 PM   #6
2003silver330i
Well all of the belts are there.
Old 08-10-2012, 08:00 PM   #7
jfoj
My Ride: '06 330CiC, '03 M5
Check for a slow leak in the fan switch located in the lower radiator hose. If there is a wet spot on the underbelly cover under this switch, you need to replace the O-ring.
See my signature below for the O-ring part number and it is very easy to replace. No tools required, if the is cold, leave the expansion cap on and just pull the switch out by squeezing the small wings. The vacuum in the cooling system will keep it from leaking, you will only loose a very small amount of coolant.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
