Nav monitor removal - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 08-11-2012, 10:46 AM   #1
Schneldorff
My Ride: BMW 330ci Con.
Nav monitor removal
Need some help removing my nav monitor to install an aux kit. I've searched and nothing I've found covers my car. 2005 330ci vert. Some say just pull the ring around the unit while the CD is open but that's not working. Some say take off the trim over the glove box and center. Anybody have a clue? Thanks
Schneldorff is offline   Reply With Quote
Old 08-13-2012, 01:37 PM   #2
johnrando
My Ride: '06 330 CIC ZHP
To remove the whole NAV unit out:
Remove the trim pieces. Remove the vents (just pull up/hard). You may not HAVE to do that IIRC, but it does allow you to reach in behind the NAV to slide it out once you do the steps below.
To remove the NAV, there are two clips on each side that hold the NAV in that you have to push in. Open the CD. Use something flat like a metal nail file... slide them into each side near the bottom, and it will release (push in) the clips for the NAV. You have to hold the files there. Slide the NAV out. There are guides online as to where the clips are. Hope that helps.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 08-13-2012, 03:54 PM   #3
Schneldorff
Thanks. Had to make sure because I saw so many posts and most of them weren't like my car.
Old 08-13-2012, 05:40 PM   #4
johnrando
No problem. Good luck.
Southern California
Old 10-02-2012, 11:50 AM   #5
IndyBigs
My Ride: 330 CiC Convertible
E46 Nav/Cd unit
Have somehow managed (aliens?) to get two cd's stuck in vert cd/Nav unit. Any ideas on how to fix? Thanks!
IndyBigs is offline   Reply With Quote
