Engine & Performance
Old 08-11-2012, 05:34 PM   #1
mike radowski
My Ride: 02 M3, 97 turbo M3
FS: Comp billet 8079 turbo 950+whp turbo
Hi Guys,
As I am always trying out new combinations I am posting my current Comp Turbo for sale. It is in excellent shape, ready to run.
http://www.compturbo.com/products/ct...dard/ct43_8079
CT43-8079
Triplex ceramic ball bearing, no side to side play
Light weight aluminum center section, water cooled
Billet 80mm compressor
79mm Inconel turbine
"Bullet" compressor nut
Ported H cover with 90* elbow welded and Vibrant Van-jen coupler(can be removed for standard silicone coupler use)
1.3 A/R T4 divided turbine housing
4" outlet
I am currently using this turbo, however I would like to try a different turbo for Bimmerfest if I can get a quick sale on this. It sells for $1880 shipped. My car went 9.54@158mph with this turbo.
I am asking $1400 shipped, and I will include the necessary water lines and fittings for install in a bottom mount configuration. Please email me at sales@maximumpsi.com, or call 732-259-9539. Thanks, Mike
Here are some pics without the bullet compressor nut. Originally this was an oil-less center section. They replaced everything and added a bullet compressor nut when it was changed to an oiled center section.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Under the knife
BMW SOB's turbo E30 - 9.20@157
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram for our latest builds and upcoming events!
mike radowski is offline   Reply With Quote
Old 08-11-2012, 10:51 PM   #2
E46<3
My Ride: M
How much is a maximum psi E46 m3 turbo kit/installed ? PM me details please.
Do you listen to House?
Have a listen to my SoundCloud
https://soundcloud.com/bryanisaac
E46<3 is offline   Reply With Quote
