Old 08-17-2012, 07:30 PM   #21
bimer21
My Ride: stick 325i
After a couple cruising over 55mph today my lean code appear again!!! And was cruising around 50mph and in raining weather! Some advise on this pls
bimer21 is offline   Reply With Quote
Old 08-17-2012, 07:59 PM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
You have replaced the O2 sensors, fuel pump & filter, so I am guessing MAF replacement would be the next most likely item to change.
Old 08-17-2012, 08:38 PM   #23
bimer21
My Ride: stick 325i
I will think about it jajaja because it is not cheaper jajajaj! But let me see what can i do about that thanks!
Old 08-17-2012, 09:57 PM   #24
BreakfastBurrito
My Ride: ///GT3 RSR
Jajajajaja
BreakfastBurrito is offline   Reply With Quote
