Old 08-12-2012, 04:50 AM   #1
estidkkt
My Ride: 316ti
Exclamation E46 bmw 316 ti white smoke ---please help
:argu e:
Hi everyone , thank you for this helpful and informative forum dedicated to BMW owners .
Now , like everyone else i got a problem with my recent purchased BMW 316TI , 1.8 litre Automatic , 12.12.2001 .
I bought the car 2 months ago from a private seller , after only one week i discovered an common problem :
1.Oil indicator light in dashboard come up (stop at first garage and topped up 5W 30 , FULLY SINT)
2.After 2 weeks , normal journey , after sitting at the traffic lights , white smoke coming from the tailpipe when pulling off ( COOLANT LEVEL CHECK - GOOD , OIL LEVEL CHECK -LOW)
Oil leak around solenoid valves- replaced o rings , no more leakage
Full service done ( oil , air filter ,engine oil , pollen filter)
3.After about 3 weeks went to Europe for Holiday , about 600 miles -900km driving with one break i hit a very bad traffic congestion in Austria , i done 10 miles in 3 hours times , when traffic was clearing up and tried to increase the speed - no power - lots of white smoke from tailpipe , engine check light and oil check light on dashboard come up , first service area pull off . ( COOLANT CHECK - GOOD , OIL CHECK - EMPTY ).
4.Getting to the destination 1200 miles(2000km) driving only up to 65mile/hour and topping up oil level every 200 miles .
5.Found a decent garage and after reading 100 posts with the same problem on forums i decided to change the CCV . So far so good ...
6. Coming back from Holiday max speed 80mph-130km/h no more problems until after 1000 miles drive CHECK OIL LIGHT ON DASHBOARD - oil was low level but no smoke anymore from tailpipe - topped up and continued driving
7.When getting close to home , at the traffic lights same WHITE SMOKE shows up again - Oil level check - level between low and max .
Please advise me what can i do now , i didn't drove the car since 3 weeks ago .
What else can cause this withe smoke ?
Thank you , any advice will be very appreciated .
estidkkt is offline   Reply With Quote
Old 08-12-2012, 05:23 AM   #2
DHK
My Ride: 2002 BMW 325Ci
You sure its really white? Usually oil smokes a blueish color. Coolant is usually the cause of bright white smoke.
DHK is offline   Reply With Quote
Old 08-12-2012, 05:29 AM   #3
estidkkt
My Ride: 316ti
Question
It looks white , i can only see it in the mirrors when at the traffic lights , and can be observed more at the night time , maybe a bit blue IDK , not to sure the colour . It does not have any coolant leakage .
Old 08-12-2012, 01:24 PM   #4
jcjdavis1
My Ride: 323ise 1999 saloon
Hi. If you are not using water and no oil leak, or oil/water mixing it must be getting burnt, how does the exhaust smell?
The older I get the wrong bit gets stiff!!
jcjdavis1 is offline   Reply With Quote
Old 08-12-2012, 04:16 PM   #5
estidkkt
My Ride: 316ti
It smells like metal burnt - , no petrol or oil burnt .
It does use a lot of engine oil ... i can't see any oil leak now , when i lost all the oil in Austria was leaking everywhere around the seals , around the sensor near the tap where you put the oil in the engine ...
The sensor is located under the cover where i mark with red :
Name:	IMG_0466 (800x598).jpg
Old 08-12-2012, 05:09 PM   #6
estidkkt
My Ride: 316ti
I put another picture where is more visible the place from most of the oil come out when the engine was warm and under pressure when sitting in traffic .
The place is number 7 .
Old 08-14-2012, 02:33 PM   #7
estidkkt
My Ride: 316ti
what part goes in the number 7 ? it is like a sensor ? anyone knows ?
