Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#21 |
I wouldn't hesitate to send my car to Vic at RDB. I've seen him turn widebody's around in a week or two.. amazing!
#22 |
I think i am, I am not sure though. All I can say is when your on it, u f@$kn on it!! U feel it spool up very fast, but then again I have never had a 6766 turbo before either.
#23 |
how much boost do you have the QSV to open up at?
VQ38DETT on twin 6262 with ProEFI128
#24 |
#25 | |
Maybe Larry or others who have stats on E85 vs Pump Gas(Race fuel) spool times could post them here.
![]() Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane! HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19 Porsche Cayenne Turbo S - stock |
#26 |
In for dyno charts with the quick-spool setup!
#27 |
A properly set up QSV is incredible....a minimum of an extra 100hp at the same RPM.(in the 3500 to 4500 range) Am I correct?
Will someone help get me up to speed? So many builds, so many variables. my question is about QSV for E46 M3 Turbo builds. I thought it was impossible to physically fit a SP QSV on a bottom mount turbo....Something about it having to be a TOP MOUNT in order to fit. So, this is not the case? What else? The turbo body has to be a twin scroll configuration? (a concept I still struggle with). WHat about the manifold requirements? Isnt it a HUGE performance coup to run a QSV on our turbo cars? Why isnt every build striving to fit one? I must be missing information. Please help me understand.
![]() Last edited by Bdave; 08-16-2012 at 05:09 PM. |
#28 | |
![]() 04 LSB M3 6sp, BSW stage 1, 19" Forgestar, PSS's, MXP exhaust, K&n intake, h&r springs, koni shocks. 87 rx7 tII 6266 BB .84 a/r in the works 00 Saturn sc2, DD, 36+ mpg |
#29 |
Basically...it spools the turbo faster by diverting the exhaust gases from all 6 cylinders through one port (divided housing have two ports...each port normally is mated to 3 cylinders in our application...dedicated but in this scenario is shared)...so double the exhaust gases through one port which spools it quicker...once a certain boost level is achieved (like 9psi or something) a bellows actuator will open the second port on the divided housing (thus not bottlenecking the exhaust gases...since at this point we have achieved quicker spool.
Essentially...it spools the turbo quicker ![]() The key...Regular non-divided exhaust manifold...mated to a turbo with a divided turbine housing
#30 |
Right! Yes, I got most of that part ... I have gone to SP website and watched their youtube videos. Very interesting. How the valve works is pretty easy to understand up to a point. See, I dont understand why a special turbo housing is necessary. If I saw a diagram I am sure the answer would be obvious.
I need to study the divided turbo housing more. That is where I get a little confused. That is what is called a "twin scroll" correct? I still dont have an answer to how SAAD made the QSV fit. Post after post said it could not be done on our cars with a bottom mount turbo. I hope it has been proven to be untrue.n it has to be, since I see this build has an HPF cast mani. The down side is two fold. The QSV itself is not cheap. PT does not make any twin scrolls correct? So the 6766 in this build was CONVERTED to a twin scroll? Must have been. How much $'s? The good news is that an HPF log or Steed mani can be used. I just want to get a handle on this build. How did SAAD make the QSV fit? How much to convert the PT to a twin scroll? Not that I have any immediate plans, but this is all very interesting. Maybe sometime down the road... Other than cost, wouldnt everyone (of us turbo FI) want a QSV? Sounds like a huge win. Supras and others have been using QSV's for a while. Why not BMW? Can the QSV be mated with larger turbos...71mm to 80mm? Why hasn't Sound Performance done this many times already with E46 M3's? After all, they make the QSV, correct? If anyone could make it fit and work it would be those guys. Puzzling.
![]() Last edited by Bdave; 08-16-2012 at 10:36 PM. |
#31 | |
#32 |
if a bottom mount turbo can be mount 3/4" lower, then you can run the QSV. With the huge H housing, it sounds like there must be plenty of room under the car.
#33 |
#34 |
I find it amazing people still go to Gintani knowing they ruin engines and build kits like crap. There manifolds look cool. But that's all there doin is lookin cool.
#35 |
I forgot to mention they bent my control arms by putting straps around them when dynoing. wow! Their all in for taking your money though.
#36 | ||
Psshhhht M3
Thank you brotha's!!! Our site is www.RDBLA.com.
#37 |
Really? I wonder why SP went to considerable effort to convert Tom's turbo to a twin scroll. They had to source a housing outside PT to do this. Maybe it is because Tom has a 76mm turbo?
#38 |
To use the quick spool valve, you have to have a divided turbine housing. Obviously Larry wanted to use the QSV on Tom's 7675.
#39 | |
I also was under the impression that PT did NOT have twin scroll housings. Until i saw pilot1ner's post, "Precision turbo makes divided housing(twin scroll).". Unless someone can tell me different, I have to conclude that PT doesnt make twin housings for the larger turbos. Larry wrote:"Tom has a 7675 turbo that we sourced a custom divided housing for and installed our SP QSV. The divided housings for the 75 turbine wheel turbos are very hard to find.... I could probably get a few more."
![]() Last edited by Bdave; 08-26-2012 at 09:10 AM. |
#40 |
You are correct, PTE does not make divided housings for all their turbos. The bigger the turbo the less likely they would be used in a twin scroll application. They make a divided housing for their large frame 71/ 76mm, the GT42 style. The 6262, 6266, 6466, and 6766 have them.
