Old 08-14-2012, 12:47 AM   #1
hollan681
My Ride: 1999 323i
final stage resistor
Hello, been reading about this infamous final stage resistor. whwere is it located, how much is it, and is it easy to remove and replace. Based on all the posts on it, i was thinking of replacing mine just as preventative measures. 1999 323i. 5 spd
hollan681 is offline   Reply With Quote
Old 08-14-2012, 01:06 AM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
search search and search. a member here has a video showing how to replace it. it's kinda hard and you need small hands. it's under your dash.
it's $40-$80 and you need to buy oem. which is behr i believe. someone found it on fcpgroton for about 40 bucks which is as cheap as you'll ever see.
Old 08-14-2012, 01:06 AM   #3
Dre325
My Ride: 2001 325i
If it's still working, I wouldn't replace it. If I remember correctly, mine was about $60 in 2009. That was my second. The first one was replaced under certified pre-owned warranty. Search for the DIY and you'll find answers to all of your questions. It's essentially behind the middle of the dash. You take the glove box out and access it from there. It's a bit of a struggle to reach in there, but I didn't find it difficult at all other than that.
Dre325 is offline   Reply With Quote
Old 08-14-2012, 01:08 AM   #4
hollan681
My Ride: 1999 323i
thank you.
Old 08-14-2012, 01:37 AM   #5
yetieater
My Ride: '03 330i
Here's an article that I wrote about the BMW E46 final stage resistor
And here's a DIY in case you needed one: http://www.bokchoys.com/differential...stage_unit.htm
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 08-14-2012, 01:39 AM   #6
Dreamliner330
My Ride: 330xi
Its not really all that hard to do. Just takes a bit of patience.
Dreamliner330 is offline   Reply With Quote
Old 08-14-2012, 03:51 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Here is my vid
Old 11-12-2012, 01:54 PM   #8
Relaxoman
My Ride: 330ci
Many thanks to you and all the people that make DIY videos. Replaced my final stage resistor and my whip is back in comfortable action. Again thanks.
Rm
Relaxoman is offline   Reply With Quote
